reptilebird
1965 kohler 8 h.p.
reptilebird
I need to find rebuild parts for a kohler 8 h.p. motor model k181s spec:30108a. I am new at this so i need some help thanks.
TT
:thumbs:
Your local Kohler dealer would be a start.
If there isn't one close by, look on eBay or the internet in general for rebuild kits or individual pieces. A lot of parts are available through aftermarket suppliers, but be forewarned -- you get what you pay for.
Most outdoor power equipment dealers can usually help you with parts, supplies, and tools, along with recommending places to have machine work done if needed.
rmaynard
:banghead:
Welcome aboard. Glad you joined. Let us know where you are located.
I agree with "TT". Many sources for Kohler parts and kits. Check eBay, but be sure you are getting genuine Kohler parts. Some of the aftermarket stuff now is coming from China. May work now, but in the long haul you will wish you had used the better stuff. :thumbs:
Bob
VinsRJ
:thumbs:
www.opeengines.com has original Kohler parts usually in stock for K-Series motors. Keep in mind original Kohler parts are more expensive than Cheena parts.
rickv1957
Hello and :thumbs: Rick
Ken B
My advice is too use Kohler parts in your American made motor. As noted, you get what you pay for. :thumbs:
buckrancher
Hi and :banghead:
I bought parts for the 8hp I rebuilt from e-bay,ope engine's and my local kohler
dealer
If you know the part number's you need somtime's you can get a good deal
on e-bay for NOS parts
:thumbs:
Buzz
You can look up part numbers for your engine on the Kohler site. Go to: http://www.kohlerplus.com/login.asp
Enter as Guest. Scroll down and click on "K series K91-662". Click on "K181". Go to page 13 of 52 to get to your spec number 30108. Then you can look up the numbers you need. Once you know what part numbers you need you can start shopping. Good luck. In case you don't have an engine manual, here it is: http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf
d180man
Hi :WRS: and if you need some part my brother sales oem and aftermarket fill free to pm or email or call 1-217-272-4090 m-sat 10-6 good luck on it ! :thumbs: :banghead:
chazm
Hello & :banghead:
:thumbs:
truckin88
Many napas stock or can next day order Kohler OEM gaskets etc.
