joel_400 59 #1 Posted January 16, 2010 Got my newest tractor running last night. So far it seems great with exception of a few little problems. First being that when I closed the hood I realized that the carb sits dead center with the edge of the hood....did the d160 with a K341 have a special air cleaner assembly or possibly a manifold that lowers the carb position? I really don't want to cut the hood to clear if I don't have to, unless thats the way they were made? Next I realized how easily I could get stuck when I took it for a drive around the yard....maybe due to the big balloon turf tires on the rear? Is there a narrower wheel available for the rear of these or will I have to make some? Or just put ag tires and wheel weights? Also after running it a bit I decided to change the trans fluid to get rid of the old, but figured I'd try it out and warm it up first. Everything I have read says to use 10w30 motor oil. Is this correct? Joel Share this post Link to post Share on other sites
Don1977 605 #2 Posted January 16, 2010 The mounting of the air cleaner is off set from the center you may lower it a little over one inch by turning it over. Don't know if that will help. Share this post Link to post Share on other sites
rickv1957 77 #3 Posted January 16, 2010 The D160 with a kohler had a notch in hood to fit the standard k341 air cleaner,also there is a 27x9.50x15 tire /wheel that was an option for the Ds,Rick Share this post Link to post Share on other sites
catman81056 3 #4 Posted January 16, 2010 Here's a few pics of my 1974 D 160, this is the only year that the K341 was used for the D. Share this post Link to post Share on other sites
joel_400 59 #5 Posted January 17, 2010 Thanks for the quick replies! I really appreciate the pictures....it gives me an idea on what to do. I should be able to make a spacer like that and won't have to cut the hood much at all! Also I may have to see if I can find a set of the 15'' wheels, that would give me a few more options on what to do for tires, since then I could leave the 26x12x12s alone for general use like mowing grass and not rutting up the yard! Joel Share this post Link to post Share on other sites
Kelly 1,037 #6 Posted January 17, 2010 I know some D's have a large 6 bolt I think and others a standerd 5 bolt wheel, if yours is the 5 bolt you can find car rims that will bolt right on and many in 15" small ford, Chry., AMC, even 80's dodge trucks have the same bolt spacing. Or is it that some have 12" rims and others 15" rims? I hope I don't give out wrong info :thumbs: Share this post Link to post Share on other sites
rickv1957 77 #7 Posted January 17, 2010 Kelly,all Ds are 6 bolt,Rick Share this post Link to post Share on other sites
Kelly 1,037 #8 Posted January 17, 2010 I just thought of that, sorry I put a edit in there. Share this post Link to post Share on other sites
catman81056 3 #9 Posted January 17, 2010 Kellys right, I think you could put 5 lug 1 1/8" hubs on it. They'er pretty easy to find. Share this post Link to post Share on other sites
pond195520032003 27 #10 Posted January 17, 2010 Joel, i believe i have a hood, but wont be back down to my house till next weekend! just was there today :thumbs: Share this post Link to post Share on other sites
joel_400 59 #11 Posted January 17, 2010 Greg! I now know you're on here too! I think I can just take a hole saw and put a notch in the one i have and maybe make an adapter to move the air filter out on mine like the pics show. Shouldn't be too hard to fab something up like that. Unless you have one laying around..... Joel Share this post Link to post Share on other sites
d180man 5 #12 Posted January 18, 2010 The D160 with a kohler had a notch in hood to fit the standard k341 air cleaner,also there is a 27x9.50x15 tire /wheel that was an option for the Ds,Rick Hi you can put chains on it ! to help in the mud we have ag tires you can still get stuck do to there speed and weight we try not to get in mud ! they like to sink ! we have a set of chains good luck like to see some photos!! Share this post Link to post Share on other sites
