KB9LOR 4 #1 Posted January 16, 2010 My GT-1642 has a hard type fuel line, can I switch it out to a flexible type? Share this post Link to post Share on other sites
Shuboxlover 484 #2 Posted January 16, 2010 Hard as in some sort of copper or steel? I just replaced mine with 1/4" fuel line from NAPA....$1.36/ft It's inexpensive and it should last for years. Share this post Link to post Share on other sites
Duff 206 #3 Posted January 16, 2010 .....or hard as in so old and dried out the rubber has all but petrified? I had a chunk of fuel line on my oldest 312 that was as stiff as a board and literally snapped like a stick when I bent it to get it off the tractor. I run soft line on all my equipment - no problems! Duff :thumbs: Share this post Link to post Share on other sites
KB9LOR 4 #4 Posted January 16, 2010 Hard as in some sort of copper or steel? No like in hard plastic, don't know why it is, unless to keep from collapsing? Share this post Link to post Share on other sites
Buzz 502 #5 Posted January 16, 2010 If you have a metal (steel/copper) fuel line now and want to switch to rubber you have to change the fittings also. Metal line use compression style fittings and rubber use barb style fittings. Share this post Link to post Share on other sites
Buzz 502 #6 Posted January 16, 2010 I think hard plastic lines use compression fittings also.......... Share this post Link to post Share on other sites
KB9LOR 4 #7 Posted January 16, 2010 I think hard plastic lines use compression fittings also.......... Nope, barb fittings, total pain in the petoot! got the tranny back in the mower today, went to hook up the fuel line and the valve came out and medded the grommet up on the valve, dang plastic crud!!! Share this post Link to post Share on other sites
Don1977 605 #8 Posted January 16, 2010 It's some type of plastic line it gets hard after it has been on there a few years. I use it, bought a bunch when I was running go karts. Go ahead and change it to a good rubber gas line. Share this post Link to post Share on other sites
bitten 134 #9 Posted January 16, 2010 Has anyone here switched to metal or copper lines? I have thought about doing it on one of mine. Dont think it would be to hard. Share this post Link to post Share on other sites
KB9LOR 4 #10 Posted January 16, 2010 Thanks for everyone's comments, I willl be replacing the hard plastic line with rubber fuel line, and bitten, have not tried that, and really to me would be a pain to convert to metal/copper fuel line, do not like compression fittings. Share this post Link to post Share on other sites
rick 264 #11 Posted January 16, 2010 Bitten, if you decide to change to metal lines be sure to use steel, not copper. The vibration will fatigue the copper line, and cause it to break. This is the reason brake lines are steel, not copper. Share this post Link to post Share on other sites
bitten 134 #12 Posted January 16, 2010 Rick I was thinking about using steel gas line. Who can afford copper :thumbs: Share this post Link to post Share on other sites
rustynut 4 #13 Posted January 16, 2010 my oldest wheel horse has the original gas line or what i think it is its just copper line runnin all the way form gas tank to fuel pump then to the carb Share this post Link to post Share on other sites
pfrederi 19,730 #14 Posted January 16, 2010 Bitten, if you decide to change to metal lines be sure to use steel, not copper. The vibration will fatigue the copper line, and cause it to break. This is the reason brake lines are steel, not copper. You might try telling that to my 55 year old Case tractors that both have copper fuel lines and a whole lot more operating hours than most wheel horses will ever see. (and my friends Farmall M that is 63 years old with copper fuel line) I think the problem with copper and brake lines is more about pressure combined with vibration Share this post Link to post Share on other sites
rick 264 #15 Posted January 17, 2010 Y'all suit yourselves, I won't use copper............ Share this post Link to post Share on other sites
linen beige 16 #16 Posted January 17, 2010 The vibration will fatigue the copper line, and cause it to break. This is the reason brake lines are steel, not copper. Not sure about the vibration thing, but brake lines are steel because copper will not hold the extreme pressure of a hydraulic brake system. Share this post Link to post Share on other sites
KB9LOR 4 #17 Posted January 17, 2010 What is the size on the rubber fuel line? I could look it up, but someone could tell me in the time it takes me to look it up.... :thumbs: Share this post Link to post Share on other sites
Duff 206 #18 Posted January 17, 2010 Pretty sure it's 1/4" ID. Duff :thumbs: Share this post Link to post Share on other sites
KB9LOR 4 #19 Posted January 17, 2010 Pretty sure it's 1/4" ID. Duff Thanks Duff, I thought that was the size, but wanted to get a second opinion! :banghead: Share this post Link to post Share on other sites
