Shuboxlover 485 #1 Posted January 14, 2010 Is this the only thing I need to rebuild the carb on my K341s? http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...e=STRK:MEWAX:IT Is rebuilding this as easy as rebuilding a briggs carb? I'v done some of those (which I thought was easy) but never have touched a Kohler one. Share this post Link to post Share on other sites
rmaynard 17,019 #2 Posted January 14, 2010 There is not much to the carb. If it is like my K241S, all you need is what is shown. Be sure to clean everything in the carb with a good carb cleaner. Biggest problem I had was a tiny piece of dirt in one of the ports. Had to probe it with a fine wire. Assuming that you have rebuilt or at least adjusted a Kohler carb before. use the initial setting in the manual, then fine tune. Should be a piece of cake. Bob Share this post Link to post Share on other sites
rickv1957 77 #3 Posted January 14, 2010 Kohler carbs are very simple,just make sure it is well cleaned,Rick Share this post Link to post Share on other sites
Buzz 502 #4 Posted January 14, 2010 Hey Shu (did I hear a sneeze? ) did you ever download the service manual for that engine? It makes it a lot easier to work on.......... Here it is: http://www.kohlerengines.com/onlinecatalog/pdf/tp_2379.pdf Share this post Link to post Share on other sites
Shuboxlover 485 #5 Posted January 14, 2010 Thanks Buzz, that'll help TONS!!!!!!!! Share this post Link to post Share on other sites
rmaynard 17,019 #6 Posted January 14, 2010 The only thing that may be missing from that kit is the carb flange to head gasket and needle valve shown in this kit: Kohler Carb kit Bob Share this post Link to post Share on other sites
