Shuboxlover
Kohler K341 question?
Shuboxlover
I need to put an oil pan gasket in the motor of the C-160 I just bought.....
Should I do anything else to the motor while I have it apart???
Any suggestions would be greatly appreciated.
Thanks
htopjimmy26
Depending on how dirty she is you could pressure wash her and replace all the external gaskets if you want. You should give the oil pan a realllll good look if oil is leaking from it as I had one with a crack in it you could barely see and only found it after an overhaul and reinstall. Good luck :thumbs:
rickv1957
If engine was running fine,just cleanup and go,Rick
