Shuboxlover 483 #1 Posted January 14, 2010 I need to put an oil pan gasket in the motor of the C-160 I just bought..... Should I do anything else to the motor while I have it apart??? Any suggestions would be greatly appreciated. Thanks Share this post Link to post Share on other sites
htopjimmy26 3 #2 Posted January 14, 2010 Depending on how dirty she is you could pressure wash her and replace all the external gaskets if you want. You should give the oil pan a realllll good look if oil is leaking from it as I had one with a crack in it you could barely see and only found it after an overhaul and reinstall. Good luck :thumbs: Share this post Link to post Share on other sites
rickv1957 77 #3 Posted January 14, 2010 If engine was running fine,just cleanup and go,Rick Share this post Link to post Share on other sites
