Countdown To Christmas!
clintonnut
Serial numbers needed
clintonnut
Hi,
I have a 953 that was the 672 tractor built in 1962. It is a very early tractor. I was wanting everyone to submit their serial number, model number and transmission case half dates to me. I want to create a document with all of the data you provide so we can see what the production runs were. I don't care if the what's left of the tractor is a console.
A transmission case half ID would look something like H6-1 meaning August 6, 1961.
I ONLY WANT 1961-1964 tractor numbers.
You can post them here or PM me with them.
Thanks
Charlie
stevasaurus
Charlie...first...there was no 672 built in 1962 (unless it was built over seas)...here you are looking at 5 models in the 1962 time frame: 2 LR 32E, 2 LR 32 R, 502, 552, 702.
My 502 model & serial # 62-18107 trans 5025 engine HT55c-3088P
ny 702 model & serial # 62-4216 trans 5025 engine K 161 S
hope that helps...would like know what you come up with. :thumbs:
clintonnut
No the serial number was 672. 62-672 is my 953's serial number.
LOL
Charlie
Sparky
Steve, I think he means it was the six hundred and seventy second tractor built in 1962 before it hit the showroom floor as a 1963-953.
Mike......
clintonnut
10-4 on that Mike.....
oldandred
Ok now if its a 953 the year was 1963
Charlie how do you know it was made in 1962?
mine was 1963 dont know what the number was but can look
stevasaurus
OK...not an expert, but as I understand it...a 62- number is a 1962 edition. I know the numbers were crazy because they just kept going and it didn't make a difference...depending on parts.............was not trying to say something was wrong...just still trying to learn and added what I have. :thumbs: Still hope it helps. That is a low number you have there.
Is it possible, that your 672 number is the first of the 1963 tractors?...with the larger engine?
Sparky
I think its like the car manufacturers Steve, who build cars for example in late 1987 but they are actually the new 1988 models and hit the showroom floor in say November of 1987.
Mike.......
brybrychrismer
my 1962 502 S/N is 62-1825 will get the trans numbers tomorrow.
clintonnut
Mike, you nailed that one too. That's exactly what I was thinking.
I currently have 5 tractors listed.
Keep 'em coming!
Charlie
stevasaurus
Charlie, Mike...I understand what you are saying now...been wondering about all of this myself. Think you are on the right track...get all the serials you can from the members...a good piece of the puzzle :thumbs:
wallfish
Here's an old quote from Wild Bill about the serial #s. What ever happened to him anyway????? He hasn't posted here for a long time.
The early 60's aerial numbers were mounted as follows
a) The 1960 Suburban serial number was stamped into the shift pattern plate which also housed the throttle and choke levers.
:thumbs: In the early run of 1961 Suburbans some of the old serial number plates off 1960 Suburban were used. To use this 1960 serial number plate the top half with just the serial number was cut away from the shift pattern portion of the plate and mounted on the hood stand of the tractor by a single sheet metal screw (on the front of the hood stand).
c) The remaining part of 1961 a decal was used.
d) In 1962 the serial number was written on the shift pattern decal and once again in the early part of 1963 you will see Wheel Horses with a shift pattern decal that will have a prefix of "62" even though the year model is a 1963.
e) In the later part of 1963 the prefix was left off the shift pattern decal for the serial number.
f) In 1964 the serial number decal was just a white based decal with black lettering about the size of a postage stamp.
g) In 1965 the metal tag was started and used during the reamain years of the 1960's.
Wild Bill in Richmond, Va.
Buzz
Garry West has been keeping track of serial numbers for a couple of years as one of the owners of the Yahoo manuals group. He's a member here, maybe he will see this and comment.
gwest_ca
Some serial numbers are in a Database in this Group
http://groups.yahoo.com/group/wheelhorsetractormanuals/
As soon as the page opens click on one of the colored column headers that you want the data sorted by. The default is the 1st column. Then click on Printable Report at the top right of the page. All the data will load onto one page that you can quickly scroll through. Use the Back button to close that page. If you click on a selected column a 2nd time the sort order is reversed.
It was a chore to come up with a method of integrating the different number formats over the years but adding zeros to the number was the ticket.
So far it appears the 953's were built in 4 lots.
Have never made an effort to collect the serial numbers - just added as I came across them with about 1900 so far. Now would be a good time to start adding to this valuable resource and make it even better. If anyone PM's me their numbers include your forum ID so it can be used rather than a name.
Garry
