exp2ex 0 #1 Posted January 10, 2010 Ok. I think I have decided to keep my c121. Got the battery charged. New set of points. Just rebuilt the carb. Some new oil and fuel. I used to have to hotwire it to get it running. I ran a wire from the + terminal of the battery to the coil. This was the only way I could get spark. I would then have to jump the start solinoid to get it to turn over. Then it would run. Can someone give me some pointers to get her running again. I have good compression and when it ran last fall it ran pretty strong, Besides these ignition issues everything appears normal. Really want to get her running without all the drama. Thanks, Degan Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted January 10, 2010 Do you have a wiring diagram? Did you check the ignition and safety switches? Did you make sure all wires are plugged in - including the ammeter connections? :thumbs: Share this post Link to post Share on other sites
exp2ex 0 #3 Posted January 11, 2010 Ok. got her running today. Had to hot wire it but at least got it running. With starter fluid. Cleaned the points again. I did rebuild the carb but does not seem like there is fuel getting to the cylinder. I did replace the fuel pump 2 yrs ago. Share this post Link to post Share on other sites
