Shuboxlover 480 #1 Posted January 8, 2010 Is down pressure good on a dozer blade.....it seems it would clear packed snow better, but also wear out the cutting edge more (I'm on concrete/asphalt). What are your guys experiences/recommendations? :thumbs: Share this post Link to post Share on other sites
Indy w h 5 #2 Posted January 8, 2010 Down pressure does eat away your wear bar but it also takes off the packed ice and snow. So ya gotta give a little to get a little Indy Share this post Link to post Share on other sites
stevebo-(Moderator) 8,527 #3 Posted January 8, 2010 If you have a hydro you can add a solid lift rod/arm to the rockshaft instead of the chain or you can add weight on the plow itself. Share this post Link to post Share on other sites
Jim_M 179 #4 Posted January 8, 2010 I use down pressure when I need to scrape down to the concrete. Half of my concrete driveway slopes down towards the road, if I don't scrape it clean it packs into ice in a couple of days and I can't get enough traction to get up the hill with any motorized vehicle that I own. Yes it wears the cutting edge down faster but I make my own wear bars so it doesn't really matter to me. Share this post Link to post Share on other sites
rockbuilt 7 #5 Posted January 8, 2010 I have never had down pressure on a WH but I have on other tractors the cons to DP are more wear on the blade and enough DP will cause you to loose steering. I have never had a problem cutting down to the surface with mine I have to wonder do you have the plow adjusted so that is below contact when in the down position so the full weight of the plow is on the ground? Share this post Link to post Share on other sites
WHC-125 4 #6 Posted January 8, 2010 Personally I wouldnt put a solid link on to replace the chain for down pressure because I have seen that done before and it broken the rockshaft completely from all of the pressure going to it. And when you are lowering you blade you dont realize that all of the pressure is on that small arm. If you wanted more down pressure you could put some weights on your plow such as a few suit case weights. That is just my own opinion. Share this post Link to post Share on other sites
