Countdown To Christmas!
donvache
ignition switch for a 551
donvache
anyone know where i can locate a new replacement switch? i have a '61 with a tecumseh hh60. switch is getting rather worn
JimD
i see them on ebay now and then.
donvache
ya, i been watching for one, but haven't found any. was hoping to find a company that still produced them.
buckrancher
If it's a self grounding switch PM Mike McGuire (mikesrj) he has some for sale
:thumbs:
TT
It's a "regular" ignition switch with the split key.
P/N is 3656 (NLA, of course) but an adequate replacement should be available through Cole-Hersee.
I have changed a few over to the "INDAK" switches used on the "throw-away" lawn tractors like MTD, AYP, etc.
hounddoghundzsa
I've got an 854 that I redid. The ignition switch had one of the three tabs broke off and needed replaced. I couldn't find a new or used one anyplace as they are no longer made. Seen a few on ebay that went for upwards of 50-60 bucks. I ended up getting one from TSC that I think has four poles. It works alright, but I have to disconnect the battery when I'm not using it or it'll kill the battery.
TT
I wasn't aware of TSC carrying a switch heavy enough to handle the starter motor current.
The 551 has a starter relay (solenoid), so a light-duty switch will work.
Have you tried to determine what is causing your battery drain, Scott?
buckrancher
The easy way to fix a 854 style starter key switch is to use a starter solenoid
and a light duty key switch one of my 854's is set up that way. works great
:thumbs:
hounddoghundzsa
:thumbs:
me + anything electical= kryptonite. I do better looking at the pictures. :banghead:
