jdwheelhorse 0 #1 Posted January 6, 2010 Hello, I just bought a wheel horse, from researching I believe it is a B80 1969? and i just bought a long frame snow plow and im having the hardest time hooking it up. I know that it attatches to the blade lift lever but where does it attatch at the rear axle? Does it attatch to the hitch pin? It seems too short to even reach back there but its the A frame that is straghtened out at the back. Any Help? PS im not sure what model wheel horse i have because the previous owners painted it and covered everything. Share this post Link to post Share on other sites
nylyon-(Admin) 8,132 #2 Posted January 6, 2010 Every thing you wanted to know about plow blades but were afraid to ask Share this post Link to post Share on other sites
kajamo240 3 #3 Posted January 6, 2010 Have to get the bracket that attaches to the rear axle. You can buy some new ones that will work off of ebay if you cant find it. Share this post Link to post Share on other sites
whfan74 2,073 #5 Posted January 6, 2010 First off...... The guys gave you great advice. I might have an extra rear bracket. Let me know........ Share this post Link to post Share on other sites
jdwheelhorse 0 #6 Posted January 7, 2010 thanks for the help. i found a way to put the rod in where the hitch connects and it will work i had to undo the deck raising mech. and arrange it different. should work nicely. Its alot more work though! I need to be ready by tomorrow, we are supposed to get 6-8in tonight. Share this post Link to post Share on other sites
hounddoghundzsa 7 #7 Posted January 7, 2010 Just pondering - anyone ever modified a long frame plow to fit on a tractor that needed a short frame??? How'd you do it?? Share this post Link to post Share on other sites
nylyon-(Admin) 8,132 #8 Posted January 7, 2010 i found a way to put the rod in where the hitch connects and it will work I haven't seen this done, I would be concerned that the plow will go sideways and break the cast at the pin. Share this post Link to post Share on other sites
Confused99 2 #9 Posted January 7, 2010 thanks for the help. i found a way to put the rod in where the hitch connects and it will work i had to undo the deck raising mech. and arrange it different. should work nicely. Its alot more work though! I need to be ready by tomorrow, we are supposed to get 6-8in tonight. The long frame plows have holes to relocate the pin to attach to short frame tractors. Jason Share this post Link to post Share on other sites
hounddoghundzsa 7 #10 Posted January 7, 2010 The long frame plows have holes to relocate the pin to attach to short frame tractors. Jason I didn't see any mention of this and was just wondering. Does anybody have any pics of this off the tractor??? Share this post Link to post Share on other sites
tophatbufflo 2 #11 Posted January 7, 2010 Read the link nylyon first posted that talks about plows Share this post Link to post Share on other sites
hounddoghundzsa 7 #12 Posted January 7, 2010 I did read the link but I didn't see or read anything about switching any thing :thumbs: Share this post Link to post Share on other sites
Lane Ranger 11,524 #13 Posted January 7, 2010 This is a 54 inch blade and the frame is somehwat different from a B-80 but take a look at the parts . Side view of B-80 with frame and plow installed. Rear axle with push pin clamped around rod at rear of the B-80 frame. Right to left view of tracor with the angle handle and lift bar hookup undernearth the B-80 with the snowplow frame. Check out the other posting mentioned above but these should help you a bit more! Share this post Link to post Share on other sites
mcwh1950 2 #14 Posted January 7, 2010 The long frame plows have holes to relocate the pin to attach to short frame tractors. Jason I didn't see any mention of this and was just wondering. Does anybody have any pics of this off the tractor??? hope this help you, this is a picture of it. picture belong to tt Share this post Link to post Share on other sites
hounddoghundzsa 7 #15 Posted January 7, 2010 The long frame plows have holes to relocate the pin to attach to short frame tractors. Jason I didn't see any mention of this and was just wondering. Does anybody have any pics of this off the tractor??? hope this help you, this is a picture of it. picture belong to tt OHHHHH those holes! Thanks for satisfying my curiosity guys!!!! Share this post Link to post Share on other sites
jdwheelhorse 0 #16 Posted January 7, 2010 thanks for the help. i found a way to put the rod in where the hitch connects and it will work i had to undo the deck raising mech. and arrange it different. should work nicely. Its alot more work though! I need to be ready by tomorrow, we are supposed to get 6-8in tonight. The long frame plows have holes to relocate the pin to attach to short frame tractors. Jason no i took the long rod out from the back of the plow and put it where the rod for the hitch goes. The 1/2" steel rod. it wont break. Share this post Link to post Share on other sites
rick 257 #17 Posted January 7, 2010 The rod may not break, but the cast iron boss the rod goes through is liable to break if it gets a twist going.....be careful Share this post Link to post Share on other sites
d180man 5 #18 Posted January 7, 2010 Hi good luck with it ! :banghead: Share this post Link to post Share on other sites
Cody 277 #19 Posted January 7, 2010 I agree, i would not hook the plow up like that as the cast iron would be likely to break, and then you would be in search for a new tranny. I would suggest getting the right bracket so nothing gets damaged. There are brackets often on ebay or im sure a member from here could hook you up with one. :thumbs: Share this post Link to post Share on other sites
jdwheelhorse 0 #20 Posted January 7, 2010 Is there anything I can make to ensure I dont break the trans. without buying the bracket. I really dont want to drop anymore money into it. I only have 175 in the tractor and plow. Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #21 Posted January 7, 2010 Without knowing your mechanical aptitude, fabrication skills, or resources, that question can't easily be answered. Where do you work? Do you know anyone with a welder? Do you have any scrap steel laying around? I'd like to tell you to build your own brackets to mount the blade frame to the rear axle housings - so if you're capable, grab some long bolts and a few pieces of steel and do your best. :thumbs: Share this post Link to post Share on other sites
jdwheelhorse 0 #22 Posted January 7, 2010 what about U-bolts? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #23 Posted January 7, 2010 Square bend U bolts would work to secure the brackets to the axle housings. You have to have a bracket with enough "drop" so the mounting rod at the rear of the blade A frame clears the underside of the transaxle. Do you have a way to drill 3/4" holes through steel? Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #24 Posted January 7, 2010 I'm not sure if this will help or not, but here's a picture of a pair of brackets that my son made to mount a blade on his 312-8. Function is more important than form, and they might not have the quick-release feature of a WH bracket, but they do the job. :thumbs: Share this post Link to post Share on other sites
hounddoghundzsa 7 #25 Posted January 9, 2010 hope this help you, picture belong to tt I dragged mine out of the barn today- guess what it's identical to the one in your picture down to the triangular shaped plate to the mechanism that angles the blade. EXCEPT no extra set of holes! :thumbs: Share this post Link to post Share on other sites
