rick 264 #1 Posted January 6, 2010 I have my K241 off the C-100 pulled down, and will be going to the machine shop this afternoon. Somewhere, I forget now, I saw where there is a machine shop that machines the big end of the connecting rod for inserts, and can offset the hole to give the piston some pop up to increase compression a little....Can anyone give me a link? Thanks Share this post Link to post Share on other sites
Helmer 0 #2 Posted January 6, 2010 I have heard only good things about this guy but haven't yet had any dealings with him. Maybe he can do what you are looking for. http://gardentractorpullingtips.com/index.htm Share this post Link to post Share on other sites
rickv1957 77 #3 Posted January 6, 2010 The rod insert has been around for many years,but I have never tried it,Rick Share this post Link to post Share on other sites
htopjimmy26 3 #4 Posted January 7, 2010 Some 10hp kohlers have K301 instead or K241 cast into them and they can be overbored to k301 12hp spec. You can machine new rods to accept bearings and update to the new piston Mahle I think, installing the 18hp K361 camshaft has more duration but I don't know if the smaller k241 would really benefit from it. Good luck :thumbs: Share this post Link to post Share on other sites
Duff 206 #5 Posted January 7, 2010 Steve's link above takes you to Brian Miller's shop. Everything I've ever read or heard about him is very positive - sort of to small engines what TT (and others I'm finding) is to Wheel Horse tractors! Duff :banghead: Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #6 Posted January 7, 2010 Some 10hp kohlers have K301 instead or K241 cast into them and they can be overbored to k301 12hp spec. You can machine new rods to accept bearings and update to the new piston Mahle I think, installing the 18hp K361 camshaft has more duration but I don't know if the smaller k241 would really benefit from it. Good luck That's the bad part about "modding" a K-241....... By the time you have it machined and buy all of the parts (the K-361 cam is grossly overrated but acceptable in most stock pulling classes - hence the popularity and outrageous price) you could probably have a nice strong stock K-321 or K-341. Share this post Link to post Share on other sites
big mike 13 #7 Posted January 7, 2010 The last I heard on another GT site was that Brian Miller was incarcerated. I would check with Kevin at Pipestone Small Engine in Eau Claire Michigan http://pipestonesmallengine.com/home.asp Kevin has the ability to do most any machining process any of use would need.I have had him balance a K series flywheel for a rebuild I am doing. Kevin did tell me he does not recommend boring non Kohler rods because of a large void he found in one. Share this post Link to post Share on other sites
rick 264 #8 Posted January 7, 2010 Thanks for the help! I was pleasantly surprised, the rod and crank are fine, and the the bore needs a .010 cleanup. I was considering the "rod mod" in the event the crank throw needed turning. This is going to be a grass cutter, not a puller. I understand what you are saying, TT. If I had needed to buy an oversize rod, I would have thought about getting Brian Miller to machine the rod for inserts, and having him offset the hole for a little piston pop up as well. I really like this C-100, if everything works out with it, I may sell the 310-8 and the C-111. I still have my eye on the 416-H, but they won't come off $1599.00. Share this post Link to post Share on other sites
rickv1957 77 #9 Posted January 7, 2010 Rick,there is always another one out there,Rick Share this post Link to post Share on other sites
Duff 206 #10 Posted January 7, 2010 The last I heard on another GT site was that Brian Miller was incarcerated. Huh???? Duff :banghead: Share this post Link to post Share on other sites
rick 264 #11 Posted January 8, 2010 I can wait for the next one, Rick. It may be a 520, LOL! It's not like I don't have something to cut grass with..... Share this post Link to post Share on other sites
rickv1957 77 #12 Posted January 8, 2010 Rick,A guy close to me has a very nice 520 with a deck,blower,cab, nice unit,asking 1500.00 but 1200.00 might buy it, great deal but cant swing it now,Rick Share this post Link to post Share on other sites
rick 264 #13 Posted January 9, 2010 That sounds good, but a little too far. Something will turn up locally, I am not in that much of a hurry. Share this post Link to post Share on other sites
jusjeepn 59 #14 Posted January 10, 2010 Be patient, it will come! :thumbs: Share this post Link to post Share on other sites
Horse Rancher 0 #15 Posted January 26, 2010 we run the rod bearing setup on almost all of our engines my pulling engine had 8 years of unlimited rpm abuse when torn down for a overhaul the crank was only .0015 under we also use napa 15w50 synthetic oil in all our engines with good success with syenthetic you will notice your engine will start easier in winter as for the 10hp i would switch to the 12 ,6more ci and more stroke Share this post Link to post Share on other sites
Horse Rancher 0 #16 Posted January 26, 2010 also forgot to mention i do bore these rods also Share this post Link to post Share on other sites
rickv1957 77 #17 Posted January 26, 2010 Sounds like you have had great service from them,Rick Share this post Link to post Share on other sites
