420lse 18 #1 Posted December 27, 2009 Now that I finally put a cab on my snow eater, I got to wondering what u guys might recomend putting on the snaps so they don't seize up? They can be a b#%&h if they get coroded. Thanks, Moe in CT Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #2 Posted December 27, 2009 Visit your local boat & marine shop or check online for a product called Starbrite snap & zipper lubricant. It always worked great on convertible top boot snaps and back window zippers. :notworthy: Share this post Link to post Share on other sites
420lse 18 #3 Posted December 28, 2009 Visit your local boat & marine shop or check online for a product called Starbrite snap & zipper lubricant. It always worked great on convertible top boot snaps and back window zippers. Excellent suggestion! When you can use a marine product you usually get quality and durablity. Thanks TT Share this post Link to post Share on other sites
Kelly 1,038 #4 Posted December 28, 2009 In a pinch bar soap (kind you use in the bath tub) works for both zippers and snaps, to lube them. Share this post Link to post Share on other sites
Jim_M 179 #5 Posted December 28, 2009 Bath soap, crayons and liquid dish soap will all work in a pinch. Share this post Link to post Share on other sites
Operator 7 #6 Posted December 28, 2009 I myself use WD-40 snaps and zippers, just hope it doesn't hurt fabric next to the zips! Randy Share this post Link to post Share on other sites
420lse 18 #7 Posted December 28, 2009 I know this might sound screwed up but I was crewing on a sailboat back in the day and the Captain would rub the sweaty grease from his nose and put it on the snaps and zippers exclaiming how he had been told how effective it was for the purpose of lube. As nautical as this dude was, Im thinking Starbright if I can find it. :notworthy: Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #8 Posted December 28, 2009 Water-based materials would wash off quickly when exposed to snow/sleet/rain, but I know that the crayons - along with candle wax or paraffin - would hang on for quite a while. I would suspect that dielectric grease would also work. If all else fails, get out the Vaseline! :thumbs: Share this post Link to post Share on other sites
whfan74 2,073 #9 Posted December 28, 2009 I would try vaseline. You can get a small tube from the check out lines at most Wally Worlds or grocery stores. On my previous trucks I had a snap on tonneau cover and it worked great. Easy to find and very inexpensive. Share this post Link to post Share on other sites
tgranthamfd 29 #10 Posted December 28, 2009 Anybody ever tried bow string wax, (archery)? Just a thought. Share this post Link to post Share on other sites
Operator 7 #11 Posted December 28, 2009 Water-based materials would wash off quickly when exposed to snow/sleet/rain, but I know that the crayons - along with candle wax or paraffin - would hang on for quite a while. I would suspect that dielectric grease would also work. If all else fails, get out the Vaseline! Never thought of it that way! But isn't WD-40 suppose to displace water? I don't use the good penetrating spray on the snaps just WD. Randy Share this post Link to post Share on other sites
Curmudgeon 28 #12 Posted December 28, 2009 WD- Water Displacement 40- 40th combination of ingredients. I use it on the snaps on my tonneau, and it works, but it's not the best. I might give Vaseline a try, might last longer. Good for many other uses as well.. :notworthy: Share this post Link to post Share on other sites
Raider 2 #13 Posted December 29, 2009 Sno Seal beeswax paste for boots and leather is what I use for stuff like that. It's easy to apply and smells good :notworthy: Share this post Link to post Share on other sites
420lse 18 #14 Posted December 29, 2009 Visit your local boat & marine shop or check online for a product called Starbrite snap & zipper lubricant. It always worked great on convertible top boot snaps and back window zippers. TT Looked up the starbrite. Is this it ? Sounds like pretty tuff stuff. http://www.starbrite.com/productdetail.cfm...s&ProductSSCat= Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #15 Posted December 29, 2009 10-4 I only ever saw it in the smaller squeeze tube, but that's definitely the same stuff. Share this post Link to post Share on other sites
420lse 18 #16 Posted December 29, 2009 10-4 I only ever saw it in the smaller squeeze tube, but that's definitely the same stuff. Thanks Terry There is a Marine Store about 5 mi. away that carrys this product. :banghead: Share this post Link to post Share on other sites
KC9KAS 4,746 #17 Posted December 30, 2009 How about using "Never-seize"? It doesn't wash off very easy, and it is somewhat of a lube. Share this post Link to post Share on other sites
