Dale 0 #1 Posted December 24, 2009 which lift design is better the older style with the cable or the newer style with the gas tank under seat with tube im puting a wheel horse together and have both want to use the one that the easiest to lift. does the bracket that goes on the seat suport that cable hooks to make it any easier to lift Share this post Link to post Share on other sites
rickv1957 76 #2 Posted December 24, 2009 Yes and no,depends on which tractor you want to install lift on,the older ones take the cable,the 161 takes the later style,Rick Share this post Link to post Share on other sites
Dale 0 #3 Posted December 24, 2009 rick i tried to get a hold of you about that electic lift did you change your mind about selling? is the newer ones better than the older ones looks like you can use a bigger cable in the newer ones i want the one that the easiest to lift by hand Share this post Link to post Share on other sites
