Sparky-(Admin) 24,119 #2 Posted December 23, 2009 So what do you actually have there Moe? 100#s on the rear?? And what is the tractor? I love the Black Hoods. Mike......... Share this post Link to post Share on other sites
420lse 18 #3 Posted December 23, 2009 So what do you actually have there Moe? 100#s on the rear?? And what is the tractor? I love the Black Hoods. Share this post Link to post Share on other sites
rickv1957 77 #4 Posted December 23, 2009 Looks like plenty of weight!,nice tractor Rick Share this post Link to post Share on other sites
bork 0 #5 Posted December 26, 2009 Does weight make that much difference? I dont have any, just chains & my big arss. Share this post Link to post Share on other sites
tgranthamfd 29 #6 Posted December 26, 2009 What did you do use your original tow hitch to support the bottom of your bracket? Maybe some angle run across you blade clip tops, what did you use to make your weight arm inbetween? I like your set up looks real nice. I have 40lbs per wheel and no chains, and I slid and spun everywhere today, dug all kind of ruts in my yard too. But it was fun!! Could you show us some close up's, maybe went you take your weights off? Thanks Share this post Link to post Share on other sites
420lse 18 #7 Posted December 26, 2009 Does weight make that much difference? I dont have any, just chains & my big arss. I weigh in at 200, so I need counter weigh for that huge 2 stage blower. I just had my driveway redone so I decided not to run with chains. The weight seems to do the trick. Share this post Link to post Share on other sites
420lse 18 #8 Posted December 26, 2009 What did you do use your original tow hitch to support the bottom of your bracket? Maybe some angle run across you blade clip tops, what did you use to make your weight arm inbetween? I like your set up looks real nice. I have 40lbs per wheel and no chains, and I slid and spun everywhere today, dug all kind of ruts in my yard too. But it was fun!! Could you show us some close up's, maybe went you take your weights off? Thanks Before the weights, I had the same problem. Yes, I did incorprate the original hitch but I also used some old bed frame to tie everything in with the axle and the plow/tiller hitch.You can see I had to extend the original hitch.I used an old slot hitch.The long carrage bolt stabilizes the weights so they don't slide around and makes it easy to remove. The weights are from ****'s Sporting Goods and run 89 cents per pound. Hope this helps. Share this post Link to post Share on other sites
chris11 184 #9 Posted December 26, 2009 I want to see some pictures of the tractor with the chrome wheels Share this post Link to post Share on other sites
420lse 18 #10 Posted December 26, 2009 I want to see some pictures of the tractor with the chrome wheels All I have is pic's without the body pannels. She's stuffed in the back of the Garage If I could get some decals, I'd finish it up. Share this post Link to post Share on other sites
HorseFixer 2,013 #11 Posted December 27, 2009 Looks like that aught to get the job done. Share this post Link to post Share on other sites
jusjeepn 59 #12 Posted December 27, 2009 Good looking weight set-up you have there. Check with Terry Dennis on decals for your 420. I know he has been working on them but not sure if he has them completed. This was my 420LSE, sold to another member here. Share this post Link to post Share on other sites
Kelly 1,036 #13 Posted December 27, 2009 What did you modify on the hood??? I turned my sons C-85 in to a C-145 this summer. Share this post Link to post Share on other sites
chris11 184 #14 Posted December 27, 2009 Good looking weight set-up you have there. Check with Terry Dennis on decals for your 420. I know he has been working on them but not sure if he has them completed. This was my 420LSE, sold to another member here. I want one of those.............. very good looking tractor Share this post Link to post Share on other sites
Cody 283 #15 Posted December 27, 2009 What did you modify on the hood??? I turned my sons C-85 in to a C-145 this summer. Looks like he might have cut the bottom of the hood to clear the snow blower when it is raised :notworthy: Share this post Link to post Share on other sites
d180man 5 #16 Posted December 27, 2009 Hi very nice tractors!! :thumbs: Share this post Link to post Share on other sites
420lse 18 #17 Posted December 27, 2009 Good looking weight set-up you have there. Check with Terry Dennis on decals for your 420. I know he has been working on them but not sure if he has them completed. This was my 420LSE, sold to another member here. Thanks Pat I will check with Terry on those decals. It's pretty much all I need to finish it up.Nice 420 :notworthy: Share this post Link to post Share on other sites
420lse 18 #18 Posted December 27, 2009 What did you modify on the hood??? I turned my sons C-85 in to a C-145 this summer. Cody is right. On the black hoods u have to cut the bottom front of the hood out to fit and lift a 2 stage blower. Share this post Link to post Share on other sites
Rideawaysenior 28 #19 Posted December 28, 2009 I spoke with Terry as I'm re-working a 420LSE also. He can not make chrome decals because he doesn't have the proper equipment. I'm working with a company in Springfield, MA that specializes in that type of work. My neighbor works for them and says he will need to take measurements and color samples to make an exact match. Did you have to re-do any of the chrome on yours? I need to have the rear wheels re-dipped and can't find a shop that can help me out with that. Jack Share this post Link to post Share on other sites
420lse 18 #20 Posted December 28, 2009 I spoke with Terry as I'm re-working a 420LSE also. He can not make chrome decals because he doesn't have the proper equipment. I'm working with a company in Springfield, MA that specializes in that type of work. My neighbor works for them and says he will need to take measurements and color samples to make an exact match. Did you have to re-do any of the chrome on yours? I need to have the rear wheels re-dipped and can't find a shop that can help me out with that. Jack I found a Company in Windsor CT that does a nice chrome job I'll need to look them up and let u know. I'm kinda suprised that no one that does this stuff has duplicated the process for the 420 decals, the chrome part must be difficult. Share this post Link to post Share on other sites
jusjeepn 59 #21 Posted December 28, 2009 Jack, I know of a small shop in Portland that will do just about anything. They are not cheap. I have yet to get a quote an any tractor parts though. Share this post Link to post Share on other sites
420lse 18 #22 Posted December 29, 2009 I spoke with Terry as I'm re-working a 420LSE also. Share this post Link to post Share on other sites
