easy Ed 0 #1 Posted December 19, 2009 I am trying to wire a wh 856. I need to know if the voltage regulator I have is right . It was operating ok when I tore it down but the wiring diagram doesn't agree with the way it was wired . The regulator terminals from right to left are marked batt. gen. field. Is this correct? The diagram isn't marked. the gen has a armature and a field post. If the reg. is marked correctly can i go ahead and wire it up according to the wiring diagram. Any help i can get will be great. Share this post Link to post Share on other sites
