64s 83 #1 Posted December 19, 2009 I'm putting together a three speed transaxle and was installing new seals all around. I noticed that the axle seals sit on top of the bearings as does the break drum seal. But as for the pulley seal, if I install it even with the top of the case, there is about an 1/8 to 3/16 gap to the roller bearing. Is this normal, or has the bearing worked itself down a little. If its down, any good suggestions to get it back into position??? Thanks guys, George :notworthy: Share this post Link to post Share on other sites
rick 318 #3 Posted December 20, 2009 George, I have never been where you are, but I would just put the seal in and not worry....If the bearing moved on it's own, it would be unusual. Share this post Link to post Share on other sites
rickv1957 77 #4 Posted December 20, 2009 With a small gap I think you will be fine,Rick Share this post Link to post Share on other sites
oldandred 16 #5 Posted December 20, 2009 its fine puter back together as long as the shaft isnt moving around up and down or side ways Share this post Link to post Share on other sites
tgranthamfd 29 #6 Posted December 20, 2009 That is the way it was on my 60 Suburban 400. I just left the seal flush with the case, hope that is the way it was suposed to be. My old seal was thicker than the replacement I found. Good luck with it. Share this post Link to post Share on other sites
