Dale
winch to lift clevis hitch attachments
Dale
has anyone tried to mount a winch to lift the clevis hitch? they make little winches to mount on 4 wheeler snow blades.
can whlvr
i was going to put one on the back on a 2inch tube hitch that i made,sorry no pics of it right now,but i put the winch in the middle of the tractor and picked up a bucket thing that attaches to my 42 dozer blade,i had to the bucket was too heavy to lift manually,then if i wanted i could use the lift on the back to lift a plow or subsoiler,the winch is not very controlable because of the cable on the roll,it gives way and also gets stuck,having only the amount of cable needed would be ideal,but i use the winch for other things and need the cable most of the time,so i wont cut it,now i use my hydro lift.here is a bad pic of it mid mounted 008-4.jpg
can whlvr
sorry to go on but here is a pic of the implement holder i made,a little welding and a winch could go on here no problem,my winch has long cables and could reach the battery 012.jpg
