Countdown To Christmas!
Daddy Don
Fuel Guage Wiring
Daddy Don
I am wiring a fuel guage on my c111 and need to make sure I am wiring it right. Does anyone have a picture of how to do it.
Save Old Iron
Don,
fuel gauges need +12 volts, a ground wire and a sender wire from the fuel tank.
The +12 is usually a pink wire (check it with your voltmeter)
Ground is usually black (check it with your ohmmeter)
and it's best to check the wire color at the fuel tank sender and attach that wire to the fuel gauge lug for the sender.
Daddy Don
Thanks theat is how I did it and the check worked out ok.
gwgdog66
Daddy Don :thumbs::notworthy: I may want to do the same on mine.
