Daddy Don 909 #1 Posted December 13, 2009 I am wiring a fuel guage on my c111 and need to make sure I am wiring it right. Does anyone have a picture of how to do it. Share this post Link to post Share on other sites
Save Old Iron 1,571 #2 Posted December 14, 2009 Don, fuel gauges need +12 volts, a ground wire and a sender wire from the fuel tank. The +12 is usually a pink wire (check it with your voltmeter) Ground is usually black (check it with your ohmmeter) and it's best to check the wire color at the fuel tank sender and attach that wire to the fuel gauge lug for the sender. Share this post Link to post Share on other sites
Daddy Don 909 #3 Posted December 14, 2009 Thanks theat is how I did it and the check worked out ok. Share this post Link to post Share on other sites
gwgdog66 23 #4 Posted December 14, 2009 Thanks theat is how I did it and the check worked out ok. Daddy Don I may want to do the same on mine. Share this post Link to post Share on other sites
