pmarq2008 0 #1 Posted December 11, 2009 I have an unheated garage up here in northern vermont that I store my 211-5 in. Is there anything I should do to ensure now problems and easy start up when I need to use it? Thanks Share this post Link to post Share on other sites
clintonnut 127 #2 Posted December 11, 2009 Buy an oil dipstick heater from tractor supply. Charlie Share this post Link to post Share on other sites
W9JAB 156 #3 Posted December 11, 2009 :notworthy: I have in the past used a 60-100watt light bulb set between the motor and batt make shur it's not touching the batt. I put it on a timer set it to give me a few hrs. of heat befor I got home to plow. :thumbs: Share this post Link to post Share on other sites
pmarq2008 0 #4 Posted December 11, 2009 Buy an oil dipstick heater from tractor supply. Charlie Will that Dipstick heater work on a small engine like these. It says for a truck or car. Share this post Link to post Share on other sites
Retired Wrencher 6,050 #5 Posted December 11, 2009 I have an unheated garage up here in northern vermont that I store my 211-5 in. Is there anything I should do to ensure now problems and easy start up when I need to use it? Thanks make sure u use dry gas so the fuel will not freeze When i use to snowmobile up in Vt. I did use a hair dry to thaw out the carb on sleds that did not use d/gas.it work just fine use some old towels around the carb. aka t1257. Share this post Link to post Share on other sites
clintonnut 127 #6 Posted December 11, 2009 If you got the dipstick tube, it would work.. The hole is big enough. http://www.tractorsupply.com/agriculture-f...-heater-0191932 http://www.tractorsupply.com/agriculture-f...-heater-0191958 Charlie Share this post Link to post Share on other sites
rickv1957 76 #7 Posted December 11, 2009 A small electric space heater directed at engine for 30 minutes might work,Rick Share this post Link to post Share on other sites
Gerry w 2 #8 Posted December 12, 2009 If you got the dipstick tube, it would work.. The hole is big enough. http://www.tractorsupply.com/agriculture-f...-heater-0191932 http://www.tractorsupply.com/agriculture-f...-heater-0191958 Charlie Thanks Charlie! I've been looking for one of those!! They work great! Share this post Link to post Share on other sites
