HankB
short frame blade for a 260 series?
HankB
I have for sale a short frame blade that originally came on a Charger V8 and I used more recently on a 314-H. A potential buyer has asked if it will fit a series 260 Wheel Horse. I searched and cannot find anything on that. Anyone here know the answer?
thanks,
hank
Kelly
I'm going to say no, pretty sure the 260 is the small vert. shaft mower.
HankB
Well, the question changes a bit. The owner got back to me and said that it's really a 252-H which is another vertical shaft tractor. I looked it up using model number 22-13KE01 and got blade number 06-42BK01. At that point I'm stuck because I don't know what that blade is.
I'm not sure how the shaft orientation would matter. In fact, I got this blade with a Charger V8 which had a vertical shaft motor. (I can see where that would matter a lot with powered accessories.)
thanks,
hank
Kelly
The old chargers had the heavy duty rearend, the newer ones don't, most of the newer small mowers not real tractors the blade mounts off the front of the tractor not the rear axle.
HankB
I see. Thank you for the info.
best,
hank
