Countdown To Christmas!
pfrederi
Home made Rear axle hitch
pfrederi
2-3 years ago I bought a home made rear axle hitch on ebay (I see he is still selling them). Looked nice but I didn't need it at the time so it went on the shelf. This year my rear axle hitch is still on the tiller tractor so I grabbed the homemade one from Ebay to put on my C175 8 speed. It didn't want to fit...I had to cut notches in it to clear the cast webs on the rear axle and enlarge the bolt holes to get it to slide close enough together so the plow frame would fit on. Also you have to mount it so the plow frame cross member is ahead of the rear axle. That makes using the latches a real pain as they point to the front and also messes up the equipment lift link. I had to replace it with some chain. That reduced the lifting clearance of the plow.
So today I took off and started plowing...2 passes and the plow frame dropped out of the attachments.
There were no holes to lock the handles. I drilled some and then realized the handles are hard up against the plow frame so you can' get any pin into the hole. I cinched the pivot bolts as tight as I could and hope the thing holds.
I don 't know what the guy used as a pattern but it won't work on a C series 8 speed...Never again will I buy from him!!!!
Had to finish the plowing with my Case DC
can whlvr
when i got my tiller it came with a differnt rear hitch than the setup that came with my 48 inch plow,the plow hitch had the cross bar,the tiller has no cross b ar and the holes for the pins are in a differnt location
truckin88
I bought from him, and it is different from OEM, but they do work, on his the bolts go above and below the axle, different from the OEM ones. This said I still prefer OEM
Dale
i think i seen them on ebay they don't have a cross bar. with out the cross bar they want to walk around on the axle
rickv1957
Ive seen them on Ebay but luckily never needed to buy one,Rick
