Dale
C-161 tire chains??
Dale
I have a C161 i was looking at it and noticed the brake is mounted on the hydro motor on the trans and is very close to the tire. is there any clearance problems when mounting chains on this model?
Rollerman
If the chains are snug on the tire & not floping around, the rear rims are the correct ones to the tractor & has the proper offset, & the hub is positioned on the end of the axle & not slid into the trans case.....you should be alright.
Putting the chains on so they are snug & won't catch on the tractor is really important.
