64lawnranger 0 #1 Posted December 1, 2009 I've got the opportunity to buy a blade like this....but will it fit my suburban 550??? I also cant seem to find a picture of one fitted to a tractor, anyone have one mounted up to their tractor with a picture??? Pro's or Con's to this blade as opposed to the HD-42 front mounted blade? Share this post Link to post Share on other sites
wallfish 18,429 #2 Posted December 1, 2009 That's the blade that I have for my RJ-58. I have both styles but haven't used them yet so I can't give you any pros or cons. It seems that you see alot of those mounts modified so the blade lifts higher. I have a 400 outside that I can check to see if the holes are already there to mount it up. Share this post Link to post Share on other sites
wallfish 18,429 #3 Posted December 1, 2009 My 400 has the holes to mount that up to the frame so that should work if you get it. The main difference with this one is that you will have to get off the tractor to angle the blade. The other uses a foot pedal to disengage the index and a rope to pull so you can angle it from the seat. Share this post Link to post Share on other sites
sorekiwi 761 #4 Posted December 2, 2009 I cant help you as far as fitting one to a Suburban, but here is a pic of one I had bolted to an RJ: and another one of the blade itself: Share this post Link to post Share on other sites
can whlvr 994 #5 Posted December 2, 2009 cool :notworthy: Share this post Link to post Share on other sites
brybrychrismer 17 #6 Posted December 2, 2009 beat it to fit and paint it to match :notworthy: Share this post Link to post Share on other sites
