dunk50 6 #1 Posted November 29, 2009 Can someone tell me what I would have to do to change my tractor bagger attachment. I see many 300 400 series on this forum with a double bagger that just has a chute and attachment to the deck. Mine is the one with the double pulley on the deck which turn another blower that hangs on the end of the deck. What makes mine so different from the others????? Share this post Link to post Share on other sites
stevebo-(Moderator) 8,528 #2 Posted November 29, 2009 Dunk, You have the powered vac bagger system. The others are just a boot that connects the the chute and is only powered by a lift blade which at times is not enough to push the leaves/grass and usually gets clogged if you do not use it with a lift blade. If you are looking to sell yours, please let me know first. Thanks- :notworthy: Share this post Link to post Share on other sites
dunk50 6 #3 Posted November 29, 2009 Stevebo, I did not know they made high lift blades and a chute for this set up. I don't pick up grass but once or twice a year so I think I could make it work if I can find the parts. I see MTD,s, Wheel Horses and almost every other tractor with just the normal set up. Mine seems to be overkill BUT it does PICKUP. I just have a small yard so it's really not a big deal. I did have to buy a new case / squirrel cage as they are made of PVC and the one I bought was cracked all over. I'll start doing some searching for a chute for a 42" deck. Thanks Share this post Link to post Share on other sites
jtmoyer 1 #4 Posted November 29, 2009 i think the regular bagger will only fit on a 37"deck. Share this post Link to post Share on other sites
stevebo-(Moderator) 8,528 #5 Posted November 29, 2009 You are correct in saying they only came on the 37 inch decks and works best with the 6 inch front wheels but i have used this set up with 8 inch fronts and it rubs when making a tight turn. Good luck. ps I have this set up if interested. Share this post Link to post Share on other sites
dunk50 6 #6 Posted November 29, 2009 stevebo, my 416H came with 6" front wheels. That is one reason that I question why it would not work. This unit is the 11 cf and thus has the large two prong fork that comes off the hitch pin and bolts to the trans. that is to carry the bags. The only difference is the 42" vs the 37" and the type blades. Do they even make high lift blades for a 42" deck. Share this post Link to post Share on other sites
