Pcoz88
B-60 wheel horse ???
Pcoz88
My B-60 wheel horse engine broke a rod.Is there a engine out there that would kind of drop in.Like a 12 or 14 horse that has electric start.Any and all info would be appericated. :notworthy::thumbs:
Pete :WRS::) :banghead:
rickv1957
Any kohler setup 8 to 16hp will work although you might have to do some wiring which is not a big deal,Rick
Pcoz88
Thanks RickV!!Appericated info alot!!
wheel horse 1045
if he went bigger than the 8 he would have to fab the drive belt gaurd and a few other things besides the wires
Rollerman
Actually the B 60 uses many of the same parts as the heavier C series.
The B 60's engine sits on an engine plate setting it up high enough that a common belt guard could be used.
Putting a small block kohler (8HP or less) or big block (10HP & greater in singles) is pretty much a bolt on if you have a Wheel Horse spec engine.
The B 60 also had a pull start only engine & you would need to rewire it to accomadate electric start if you go that way.
The B 60ies are kinda an odd ball & you don't see to many.
sorekiwi
I just dropped a 16 onto a B-80, and used the B-80 belt guard, PTO brackets etc.
I think the only bits I had to change were the longer throttle cable, and the exhaust off the donor C-160.
So probably wiring and a battery box will be all you need...
Pcoz88
Thanks for all the reply's!! Can somebody point in the right direction for an engine?Thanks.
Sparky
Post a wanted ad in our classified section with what your looking for and your location. Location is real important since although motors are shippable its very expensive.
Good luck!
Mike...........
