Countdown To Christmas!
rmaynard
Wheel Horse Paint
rmaynard
:notworthy:
I'm now thinking of using an Acrylic Urethane single-stage paint. Found one from Kirker called Flame Red. It crosses to GM #81, and is a near perfect match to my B-100's original color. I matched it to my NOS shift plate, and to the red under a decal on my dash, and under the decal on the side of my hood. Costs about $88 for a one gallon kit (paint & activator).
Kirker Ultra-Glo Urethane
Kirker Acrylic Urethane Flame Red Chip Chart
I'm using a 2-part gray epoxy primer.
We'll see how long it takes for me to change my mind again. :thumbs:
Bob
cedarstrip14
try using new holland red valspar paint.. i think it has a better color and is not as bright as IH.. i restored several tractors and thought that looked the best. you can get it at TSC too.. gary
rmaynard
Thanks for the suggestion Gary. Kirker Flame Red urethane is very close to New Holland which I like too. However, Valspar New Holland Red is only available in an Alkyd Enamel. Alkyd's tend to fade and chalk over time. No UV protection. This is why I am going to use an Acrylic Urethane. Very tough finish, excellent UV protection and no chalking.
Bob
rickv1957
Bob,I have used a lot of urethane on wheelhorses,it sure does look nice.allthough it is a hard paint that chips easy,Rick
rmaynard
Did you use an epoxy primer under it?
Bob
rickv1957
Bob,yes I did,Rick
rmaynard
Just checking. Had the front of my Ford van painted with Urethane about a year ago. Seems to be holding up good.
Thanks for the input Rick. All info is appreciated.
Final questions for you. If you were painting a tractor today, what would you use?
Bob
rickv1957
I would use the urethane on my non workers and factory wheelhorse paint on a user,just my two cents worth,Rick
rmaynard
Rick,
Thanks again. Always appreciate your input.
Bob
