WH Raider 10 0 #1 Posted November 16, 2009 Evening Ladies and Gents, Here is an interesting question I have. I recently bought a Raider 10. when i got it all the wire near the dash were disconnected except for a few. i printed a wiring diagram for a 69 or 73 Raider 10, 12 ,14 and reattached them according except mine is a four prong where the 69 or 73 wiring diagram showed 5. i am missing a prong for magneto I think. Now I had it running w/o the battery in both off and run/run with acc. it would only turn off it i turned the key to start. i figured it was doing that because i had no battery. Now i have a battery and it still isn't working right. I need to disconnect this wire in order to start the tractor: then when i try to reconnect the wire it turns off. but if i switch the key to off before i reconnect the wire it doesn't turn off but then i can turn it off by turning the key to run/run with acc. What do i do to fix this and why is it happening? If you need any additional info please don't hesitate to ask. i want to solve this problem and you guys are the best help i can get! Thanks, Dan B. Share this post Link to post Share on other sites
Kelly 1,035 #2 Posted November 16, 2009 Well from what you said and the pic. of the switch you have the wrong ign. switch, kinda sounds like it is for batt. ign. not mag. ign. Share this post Link to post Share on other sites
WH Raider 10 0 #3 Posted November 17, 2009 thanks for the response! Dan B. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,842 #4 Posted November 17, 2009 What are the numbers on your data plate? 1-0300? + 6-digit serial #? Garry Share this post Link to post Share on other sites
WH Raider 10 0 #5 Posted November 18, 2009 1 0300 6 and 779054 Dan B. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,842 #6 Posted November 18, 2009 The 4-position 5-wire ignition switch is still available from Toro # 8362. Terminals should be marked L-B-M-S-R Garry Share this post Link to post Share on other sites
WH Raider 10 0 #7 Posted November 18, 2009 Sweet! Thanks for the information Garry. Dan B. Share this post Link to post Share on other sites
