truckin88 104 #1 Posted November 15, 2009 Is it possible to put a single cyl kohler on a C-175 if needed? I had a line on a 16 K out of a 416. Thanks, Will Share this post Link to post Share on other sites
Sparky-(Admin) 23,143 #2 Posted November 15, 2009 Phsically it will fit like it was allways meant to be there. If you do get the motor off the 416 try to get the ignition switch and the wiring components. Mike....... Share this post Link to post Share on other sites
truckin88 104 #3 Posted November 15, 2009 AWESOME!!! Share this post Link to post Share on other sites
rickv1957 74 #4 Posted November 15, 2009 That is a fairly easy swap to the single,might have to alter wiring and a different switch,Rick Share this post Link to post Share on other sites
