Countdown To Christmas!
Rollerman
D160 project/beater tractor
Rollerman
Picked this up about 3 weeks ago.
It's a 74 vintage with the Kohler K341 single.
Nice tight steering, trans pulls well & doesn't creep.....but!
The governor was not working.
I pulled the motor down & found the paddle on the governor shaft was faceing the wrong way.
(For those of you who have not been into a Kohler...thats the part that makes contact with the pushrod inside the gov gear to slow the engine if it over revs or speed it up if it's lugging)
I ordered up a gasket & ring set & proceeded to put things back together right.
Runs like a top now....well did before to, but it's not a screamer now.
Next I bought a 3 point from Jim M & found a box blade on Craigslist.
It actually up in the pics with 6 pounds of rear tire pressure.
I'll replace the top link with a longer one since it's adjusted out & also need to adjust up the lower arms some to level the box blade out & get a little more heigth.
I had an hour of daylight left when I got home from work....(weird!) so I went out front of the house & filled all the low spots in the gravel parking area...then to the utilities easement behind my garage to level off the dirt.
Had so much fun I didn't get off & shoot pics till after it was dark.
Next up....lights, cab, box blade rotater, heated stering wheel. (Duke just :notworthy:)
jusjeepn
Stephen, That is far from a beater. It looks to be in great shape and sounds like it will definitely earn it's keep! Nice find and fix!
can whlvr
nice setup,that will make easy work of leveling gravl.
rickv1957
The D-Series tractors are very good workers,open to several attachments with the 3pt and have a lot of pulling power compared to the smaller units!
Don1977
It looks better than a beater. I worked on you picture a little.
Sparky
Thats a beater Stephen :notworthy: ! Man I'd hate to see what catagory most of mine fall in :thumbs: .
Good lookin ride pal.
Mike.......
bustedglass
Looks good. Do you have any better pictures ?
Rollerman
Thanks again for the comps.
You know today while I was digging stuff out for the Wapakoneta swap this weekend I thought about getting both the D160 "beater" & 18Auto out for some pics.
Ran short on time fixing a few things on my truck.
I will though soon enough & post some new ones.
Suburban 550
Nice tractor, Stephen. :thumbs: Too nice to be considered a beater. That should get the job done for ya. :notworthy:
whfan74
So where is the beater!?!?!?!? Is it sitting behind that D with the box blade on the back??? :notworthy:
Looks as though you are going to have some fun with that one!
Hope you and Jim had a good trip to the show!
