HorseFixer 2,013 #1 Posted November 4, 2009 Has anyone repaired Hydraulic Cylinder on a C-120? It looks welded on both ends and does not look like it comes apart. It looks like its leaking around the Chrome Cyl Rod. Is there a seal that can be replaced around that rod? :scratchead: Share this post Link to post Share on other sites
HorseFixer 2,013 #2 Posted November 4, 2009 Does anyone have any info? :scratchead: Share this post Link to post Share on other sites
C-Series14 15 #3 Posted November 4, 2009 There is a manual for repair of the hydraulic lift valve and cylinder, I have one. It shows the three types of cylinders. The welded one should have a snap ring holding the rod guide bushing in the cylinder. Only the GT-14, 18hp Auto, and the D-Series cylinders are not repairable. Share this post Link to post Share on other sites
Sparky-(Admin) 23,752 #4 Posted November 4, 2009 Sorry I cant help Duke, never messed with one before. Mike...... Share this post Link to post Share on other sites
wheel horse 1045 2 #5 Posted November 4, 2009 my C160 is doing the same thing so im hoping you find out and let us know Share this post Link to post Share on other sites
chazm 413 #6 Posted November 5, 2009 Duke - all hyd. cylinders have a seal for the rod & piston assy. If yours is welded together - sounds like a job for a Hyd. shop to rebuild, if they can But ,if they are like the ones around here - they'll try to sell ya a new one for $$$$$$$$$ Chaz :hide: Share this post Link to post Share on other sites
HorseFixer 2,013 #7 Posted November 5, 2009 There is a manual for repair of the hydraulic lift valve and cylinder, I have one. It shows the three types of cylinders. The welded one should have a snap ring holding the rod guide bushing in the cylinder. Only the GT-14, 18hp Auto, and the D-Series cylinders are not repairable. Hey C, Can you hook me up with a copy of manual or point me in the right rirection to get it? Her are some pics of Cylinder. Share this post Link to post Share on other sites
C-Series14 15 #8 Posted November 5, 2009 Does yours have the snap ring on the rod side? You can download the manual on Toro's site, use 1-0485 for the VIN... Share this post Link to post Share on other sites
HorseFixer 2,013 #9 Posted November 5, 2009 Does yours have the snap ring on the rod side? You can download the manual on Toro's site, use 1-0485 for the VIN... Nope I just went out and took MORE pictutures and posted them up on the thread before your reply, I went out and double cked made sure I wasn't having a azzhole attack! For once i wasn't By the way looks like I need to degrease the underside of this tractor! Thats what happens when ya have a leaking Cyl and dont fix it like the last guy who owned it! <_< Share this post Link to post Share on other sites
sorekiwi 761 #10 Posted November 5, 2009 Maybe he didnt fix it 'cause he couldnt work out how to get it apart! Share this post Link to post Share on other sites
C-Series14 15 #11 Posted November 5, 2009 OK...see the pics of the rod end. I guess there is no snap ring! I am confused now going by what the manual says... :scratchead: Share this post Link to post Share on other sites
HorseFixer 2,013 #12 Posted November 5, 2009 Maybe he didnt fix it 'cause he couldnt work out how to get it apart! Gee ya think? Well I downloaded the El-Manuel and it Looks as if someone may have changed this Cylinder. The manuel says it has a retaining ring on the rod side to take it apart as you can see by the pics "NOPE" <_< looks like I got screwed again! <_< A matter of fact, sometimes I feel I get Screwed more than Hue Heffner! :ychain: Share this post Link to post Share on other sites
can whlvr 994 #13 Posted November 6, 2009 not sure about originality buy my c160 has the same cylinder,welded shut,and my cylinder is leaking also. Share this post Link to post Share on other sites
Indy w h 5 #14 Posted November 6, 2009 Hey duke I don't think the welded cylinders are rebuildable. Indy Share this post Link to post Share on other sites
Sarge 3,470 #15 Posted November 6, 2009 The cylinder can be fixed but it has to be put into a lathe , rebuilt and re-welded very carefully. Not fun...and expensive. Sarge Share this post Link to post Share on other sites
mack1605 8 #16 Posted November 6, 2009 take it to a hydro shop mine was cut open ,rod polished replaced the seals and welded back up works great and no leaks Share this post Link to post Share on other sites
CasualObserver 3,411 #17 Posted November 6, 2009 Or watch flea-bay and pick up a used rebuild-able one. I read in a manual or service bulletin (can't find it now....) that the original #6618 cylinders were not meant to be rebuild-able, but the replacement #105254 cylinders were. Edit: Found it... Service Bulletin #177.... Share this post Link to post Share on other sites
HorseFixer 2,013 #18 Posted November 6, 2009 :thumbs: Jason and everyone else that assisted in this... Well looks like I will have to find a donor Cylinder Its not leaking that bad like all over but it does leave a spot on the floor. Ill just throw a rag or put a pan w/some kitty litter in it for the time being till I find a cylinder. :notworthy: Share this post Link to post Share on other sites
KyBlue 655 #19 Posted November 6, 2009 Duke, a Hyd. shop should be able to rebuild it.. I have taken welded cylinders to a local place in the past and they ahve rebuilt them, course now they were larger ones....off a dozer but it can be done. Share this post Link to post Share on other sites
billyban1 0 #20 Posted November 6, 2009 I rebuilt my C-160 cylinder, but you need a lathe and a good welder. I chucked the cylinder housing in a lathe and use a narrow cutting tool to cut thru the factory weld. $5 worth of o-rings and welded it back together. That's been about 5 years ago and it still holding. Share this post Link to post Share on other sites
