Countdown To Christmas!
tgordonjr
busted rear axle
tgordonjr
So I have been in the process of restoring my 211-5 and have finally got it down to frame and motor, so I can sandblast it and paint it. I was trying to get the large pully off of the rear axle by using a dead blow hammer and some man power since i figured after the set screws were out it was just pressed on. well I guessed wrong or used a little to much man power :hide: and ripped the pully right off, along with the shaft, gear, and part of the aluminum axle housing. So now there is a nice hole at the top of my axle. :scratchead: Is there another axle that is stronger that will bolt up to the 211-5? I only ask because trying to find parts for the unpopular 211 series is almost impossible. :ychain:
baerpath
I have a 211-5 rear sitting beside the garage. How to get it from here to Reading is the problem If you figure that part out we'll be all set :scratchead:
Duane
Canajoharie NY
tgordonjr
uhmm
