gregg.d250 0 #1 Posted November 2, 2009 Hi all- I'm trying to figure out if the following side-discharge 42" deck (apparently off a B-Series) will fit on my C-81. The C-81 came with a 38" deck which is.... well.... let's just call it "well ventilated" by the ever-active tinworm...... I came across the following deck, and being somewhat new to the W-H world, I was wondering if this will fit with minimal to no mods/tweaks- 0542MR04 81019 Thanks in advance for your input- Gregg in VA Share this post Link to post Share on other sites
Docwheelhorse 2,778 #2 Posted November 2, 2009 Hi-- a 42" deck off of a B series with a HORIZONTAL SHAFT ENGINE--i.e. B80, B100 etc... will fit a C81 without an issue. A 42" deck being spun by the 8 hp kohler will be a bit under-powered. Keep the blades razor sharp and don't try and cut a hayfield and you should be OK. Tony Share this post Link to post Share on other sites
gregg.d250 0 #3 Posted November 3, 2009 Thank you Tony. The 42 was off a B-80 with the horizontal shaft Kohler. I won't be cutting any hay with it, that's for sure! Not with 8 hp and 11 lbs-ft of torque coming from that little mill in the C-81. Anyone know how to decode the deck model numbers? Is there a resource somewhere on the site I haven't found yet? Thanks - Gregg Share this post Link to post Share on other sites
wheelhorse101 0 #4 Posted November 3, 2009 i had my self a 48" deck on my c-81 and it worked great. Share this post Link to post Share on other sites
tarcoleo 119 #5 Posted November 3, 2009 i had my self a 48" deck on my c-81 and it worked great. Me too. (with a 11 hp or a 13 hp Honda up front). Tom in RI Share this post Link to post Share on other sites
wheel horse 1045 2 #6 Posted November 3, 2009 1 time in band camp i had a 48 inch deck and i played trumpet and... :scratchead: Share this post Link to post Share on other sites
can whlvr 994 #7 Posted November 4, 2009 i smoked my magnum 8 hp spinning a 42 side,she did last about 10 years,i couldnt allways get to the lawn when i should have. Share this post Link to post Share on other sites
Sparky-(Admin) 23,794 #8 Posted November 4, 2009 Anyone know how to decode the deck model numbers? Is there a resource somewhere on the site I haven't found yet? Thanks - Gregg Go here and enter 05-42MR04. https://lookup3.toro.com/partdex/index.cfm Mike........... Share this post Link to post Share on other sites
gregg.d250 0 #9 Posted November 4, 2009 Thanks for all the inputs and anecdotal stories fellas. Sparky - I followed the link - thanks! I'll be sure to take 'er easy if I mow taller grass. Or just use another mower!! Ya can't have just one!! Gregg in VA Share this post Link to post Share on other sites
