chazm 413 #1 Posted November 2, 2009 Need some help guys - I pulled the 753 in to see what the engine needed to get running Well ... the engine on the Blue horse has no cooling tinware so... No ID numbers on it - My guess is its a Tecumseh , maybe a 7 hp from what I can tell from the carb & air filter. As you can see ,its a trans-plant Also this must have been a deluxe 753 model, since it has a city horn too Any Ideas welcome Thanks,Chaz :ychain: Share this post Link to post Share on other sites
WH nut 553 #2 Posted November 2, 2009 Id say its a Tecumseh, what size is anyone guess Share this post Link to post Share on other sites
Indy w h 5 #3 Posted November 2, 2009 Looks like a tucky to me. Nice horn!! Indy Share this post Link to post Share on other sites
chazm 413 #4 Posted November 2, 2009 From what I could tell from the carb - it's a 7hp or smaller I guess the only way to know for sure is to pull the head and measure the piston size. Next question is ... can any body hook me up with the cooling tin ware ?? It had a stater /generator on it ,so will need that type of tin ware Please Pm me if you can help Thanks all Chaz :hide: Share this post Link to post Share on other sites
Indy w h 5 #5 Posted November 2, 2009 R u gonna leave the tucky on there or r u gonna put on a kohler 7 hp??? Indy Share this post Link to post Share on other sites
chazm 413 #6 Posted November 2, 2009 Good question Depends if I can find need parts for the tucky or a reasonable priced K161s :scratchead: Share this post Link to post Share on other sites
Horse Fanatic 51 #7 Posted November 3, 2009 I like the union on the exhaust pipe! Share this post Link to post Share on other sites
chazm 413 #8 Posted November 14, 2009 Well guys, I found a Kohler 7 hp for the Blue Horse. Wasn't complete,just a long block. Will need torn down and gone over. I do need a carb for it - don't even know what carb goes on it, so if any body can tell me what carb number goes on on K161 I would appreicate it thanks ,Chaz :notworthy: Share this post Link to post Share on other sites
stevasaurus 23,446 #9 Posted November 14, 2009 the early production K161 came with a Carter "N" model side-draft carb. Late production K161 are equipped with Kohler side draft carbs. No letters or numbers are given for the Kohler carb. Don't know how you could tell the difference between early and late production, maybe the serial #...but I would guess the carborators may be interchangeable. If you have the linkage, you may be able to tell from manual pictures. Anyway...there seems to be only 2 choises. :notworthy: Share this post Link to post Share on other sites
TT-(Moderator) 1,162 #10 Posted November 14, 2009 I'll have to look to be sure, but I think the Carter "N" and/or Kohler carb is either a #18 or #20 - depending on application. New ones are very expensive but you should be able to find a good used one here on the internet. Share this post Link to post Share on other sites
chazm 413 #11 Posted November 14, 2009 TT - You Da Man Thats the info I was looking for. Thanks for your help, Chaz :WRS: Share this post Link to post Share on other sites
chazm 413 #12 Posted November 14, 2009 oooppps , sorry Steve Thanks for your help too Chaz :thumbs: Share this post Link to post Share on other sites
