Edinnj 0 #1 Posted October 27, 2009 I have a wheel horse 10 h.p. model 1054,made in 1964. It was only made for two years. I only use this for snow plowing.got the special wheel weights,but it still slips in the snow,would like to use a wider tire for more grip. Also the tires are original,and I think they are too hard for gripping in wet snow. Any help on this matter. I am thinking of selling the mower deck,since use a toro z turn for cutting the grass. Ed in Nj :scratchead: Share this post Link to post Share on other sites
nylyon-(Admin) 8,293 #2 Posted October 27, 2009 Ed First, the 1054 was made only 1 year, 1964. Have you tried chains on the tires, that would be your best bet for traction. Share this post Link to post Share on other sites
Indy w h 5 #3 Posted October 27, 2009 Hello I think the original tires for the 1054 are 27/850/15. They are obsolete a buddy of mine found a set of 760/15 ags that work well. You could fill them up with windshield wiper fluid and gain some pounds there. Hope it works out for ya!! Indy Share this post Link to post Share on other sites
clintonnut 127 #4 Posted October 27, 2009 The 1054's had the BFG 6.40x15. I have American Farmer 7.60x15 on mine and they really bite. The 27x8.50x15 tires are for GT-14 but will work on your tractor. Here's my tractor with the new tires at the bottom of this page: http://www.wheelhorseforum.com/index.php?showtopic=9560 Charlie Share this post Link to post Share on other sites
pfrederi 18,916 #5 Posted October 27, 2009 Just put chains on what you have. For snow plowing wider tires are not an advantage. You want to concentrate the weight. Dedicated purpose built snow plows (think Walter Snow-fighters at the airport ( and in some snow belt townships) use single tires no duals) Share this post Link to post Share on other sites
Jim_M 179 #6 Posted October 27, 2009 I just wanted to add my 2 cents....I think I would hang on to the deck. They're getting hard to find and it will make your tractor worth more if you decide to sell it some day. Share this post Link to post Share on other sites
beeman 0 #7 Posted October 27, 2009 always keep deck every body want a deck when you sale. and i've had better luck with ag tires over chains. Share this post Link to post Share on other sites
Michcruiser60 0 #8 Posted October 28, 2009 I've got Goodyear 760x15's on my 953, with the rear weights. It works great plowing snow. Welcome, Mich60 Share this post Link to post Share on other sites
bitten 134 #9 Posted October 28, 2009 Ed Hello and Welcome to the group. If you are going to replace your tires for snow go skinny. I would put chains on it before I tried anything else. Even with ag tires chains work wonders. Share this post Link to post Share on other sites
Save Old Iron 1,571 #10 Posted October 28, 2009 :hide: Ed, think of it this way - lets say a normal sized back tire has a "contact patch" of say 20 square inches per tire ( how much rubber meets the road so to speak) - on each back tire there may be 200 pounds of weight - so each tire has a force of 200lbs/ 20 square inches = about 10 pounds per square inch of traction. If you go to a thinner tire the same same weight is now distributed over a smaller "contact patch" so you get a larger pounds per SQUARE INCH pressure on the surface your plowing. A wider tire would divide the same weight out over a much larger area and therefore a smaller pressure on the surface your plowing. Go with the thinner tires for more traction in the snow - turfs are better than ag's and chains on turfs are probably the best route. :scratchead: Share this post Link to post Share on other sites
HorseFixer 2,013 #11 Posted October 28, 2009 Ed First, the 1054 was made only 1 year, 1964. Have you tried chains on the tires, that would be your best bet for traction. Great tractor the 1054 Well directly thats correct for just 1054..... But the 1054A was made in 1965 and was vertually the same tractor just the tire width steering linkage change and engine #, Avg person looks at the Decal on the hood both say just 1054. Yep I agree with everyone else keep the deck, But most all these tractors show better without em :scratchead: Share this post Link to post Share on other sites
