brybrychrismer
fly wheel on h55
brybrychrismer
:scratchead: for the life of me i can't get the fly wheel lose.... Any tips or tricks for this process :hide:
Indy w h
Put ya a prybar or big screwdriver between the flywheel and the case
and apply some prussure outwards and with a lead hammer or a hard
rubber mallet wack the threaded end of the crank. It should come off
with a few blows. The flywheel and crank are both tappered so a few
whacks should do it.
Indy
Don1977
Run the nut level with end of the shaft and use a brass hammer. Don't be afraid the hit it. I was 14 or so when I was trying to get a fly wheel off of a gokart engine. Took it over to the local machinist. He came out with a big hammer one lick and off it came. Said that will be 50 cents. I found out right there that I was not using a big enough hammer, haven't forgot it either. :scratchead::hide: :ychain:
