Countdown To Christmas!
wfopete
Horse Maintenance
wfopete
What kind of slick work tables/stands are out there for horse maintenance? I hate being on my hands and knees when there are better options out there. I work on motorcycles but those lifts are too narrow plus do not give access to the underside of the deck. I saw the vendor that had the
KyBlue
Most of the tables that Ive seen, For cycles, have add on Side tables to make em Wide enough.. there are also some Scissor Lifts out there...For not that Much Money.
For My Resto Job.. Im trying to get a rotisserie put together, just to make it way easier, specially when it comes to painting...
Don1977
You need one of these in a smaller size.
KyBlue
Somebody posted pictures of one off WFM awhile back...
Im using the 3/4" Hitch Mount in the back of the UniDrive, and bolting it to the front of the frame... Just using two Engine Stands - 2000 lb capacity should be MORE than enough!
fireman
Here are the plans for a snowmobile lift I was going to build before I found my hydraulic lift table. It can be modified to put anything you want on top of it.
sorekiwi
Here's the one from WFM, one day I'll build one...
and here's the production line at Toro:
zero
The production line photo is really neat and very informative as to the sequence of production.
do you have any more of these? I would love to see them
Looks like they utilize the mule drive attachment point to support the front of the tractor. I will
have to build a set of brackets for my rotisserie to accommodate the WH. Its currently
occupied by my M151 Jeep
%7Boption%7Dfile:///Users/jamesdavidson/Pictures/iPhoto%20Library/Originals/2006/Aug%2017,%202006/100_0166.JPG%7Boption%7D
sorekiwi
Somewhere, a couple of years ago, there were two Powerpoint presentations documenting the final run of the "Classic" tractors. That photo is from one of those presentations.
Trouble is, I have no idea where it came from... :scratchead:
Anyone else remember?
bitten
Man I want to see that final run of the classic. Im not real good at finding stuff on the net but will give it a try.
can whlvr
I know this doesnt help other people but i still have the two downloads of the last run of wheelhorse,problem is i have no idea how to put it out there for everyone,im sure that who ever put it on red square will chime in.
MikesRJ
I have one of the PP presentations and will post them on the MWH site. Then I will update this post with the link. If you'd like to send your two copies to MWH then send to manuals (at.at) mywheelhorse (dot.dot) com, or post them to the manual posting section of the forum, and I'll get them both up there. I'm in VA for the weekend so it will have to wait till tomorrow.
