rockbuilt 7 #1 Posted October 19, 2009 I am going to pull the mower decks off for the winter I was wondering has anyone tried spraying the underside with Teflon paint if so how are the results I want to ready them for next year but I want to do it right If this is the thing to do where can I get it Share this post Link to post Share on other sites
Shuboxlover 484 #2 Posted October 19, 2009 I have never used that before, but I just restored my tractor and mower deck. I had mine sandblasted and powder coated at a local place and it only cost me $80 total. I figured by the time I bought sandpaper, primer, and REALLY good paint I would have that much in it, plus all my time. I would definitely check into powder coating, it's not as expensive as everyone thinks it is. Plus it'll last WAY longer than paint. Good luck. Share this post Link to post Share on other sites
rockbuilt 7 #3 Posted October 19, 2009 Thanks I think I'll look into that I went to a local ag stor today and they sell a graphite paint called graphite lube it is supposed to work great but I have to wonder how long it will last powder coating sounds like a better solution Share this post Link to post Share on other sites
GlenPettit 1,718 #4 Posted October 20, 2009 Powder Coated Paint is the best way, but also use the Graphite SLIP SPRAY Lube. For me, it lasts the entire mowing season, 3 hrs @ for 24 weeks; 95% of the Graphic is still there, just touch up on the worn spots. Nice thing about the Black Graphite is that wet grass doesn't stick to it, it's that "grass juice acid" that eats through the paint and rusts when stored during the week. I use the qt can for brushing on most of the underside deck, and then the spray for the spindles (cover the threads). Also using the 'Gator Blades' above your regular blades will greatly help with the "throw" and really reduce size of the clippings. Good Luck, Share this post Link to post Share on other sites
Sarge 3,470 #5 Posted October 20, 2009 Last 2 decks I've rebuilt were coated with POR-15 . So far, seems to work very well, even wet grass doesn't stick to it very well . It can be topcoated with any color with a good scuffing . This stuff stops rust dead and is nearly impossible to remove. Expensive at around $60/quart online but if you look around there are deals out there. Best bet is the six-pack of small 4 oz cans, one little can will easily cover a 48" deck inside/out . Just be sure to use acetone to clean your brushes/equipment and allow it to dissolve the coating-otherwise whatever it touches it does not come out . If you have inert welding gas such as CO2 , helium or argon you can store partial cans w/plastic wrap under the lid. This stuff will weld the lids back to the steel can so using the wrap for storage is a must. Wish they would have had this stuff 20yrs ago! Sarge Share this post Link to post Share on other sites
Shuboxlover 484 #6 Posted October 21, 2009 GlenJeri.....can you tell me a little about the gator blades you speak of, I have a 42" SD deck. Didn't mean to post this here.... I'll start a new thread, sorry. Share this post Link to post Share on other sites
GlenPettit 1,718 #7 Posted October 21, 2009 GATOR BLADES, also called "Commercial" or "Raptor" are available from all the part's suppliers (RCPW, Jacks, etc . . . see list here), cost is about the same as replacement blades, $15 @. In fact Auto Parts stores & most local Sm Engine Repair shops can order and have no shipping, which makes then less than by mail with shipping costs (Google: to find size charts). All new, better quality riding & push mowers use these Commercial Blades on their tractors now, look under at them when you're the Home Centers. On your deck, place the Gator Blades above your regular blades at a 45 Share this post Link to post Share on other sites
