wallfish 18,792 #1 Posted October 18, 2009 Should the hydro tranny for this tractor free wheel with out turning a valve? I drove the tractor around for a while after letting it run for 15 min or so and it didn Share this post Link to post Share on other sites
TT-(Moderator) 1,169 #2 Posted October 18, 2009 That's fairly normal for the Eaton 1100 models, John. There should be some resistance and they sometimes tend to push easier with the DCL in the "full speed ahead" position. Share this post Link to post Share on other sites
wallfish 18,792 #3 Posted October 18, 2009 WHEEEW!!!!!!!!!!!!! It rolls pretty easy with the lever neutral. Of coarse, I didn't really push it around much. I can check it out some more when it stops raining in a couple of days. Thanks for the relief! I thought I was going to start smoking again, it's been 2 weeks without a smoke. Share this post Link to post Share on other sites
sorekiwi 761 #4 Posted October 18, 2009 I almost got caught with this when I got my 520H - was so used to the old Sundstands not wanting to be pushed unless the tow valve was open. Guess the Eaton is a different animal!! Share this post Link to post Share on other sites
wallfish 18,792 #5 Posted October 18, 2009 I don't think my C145 pushes around and that has an Eaton but I can't remember if I even tried to push it. Hmmmm I guess I'm going out to push tractors in the rain. Share this post Link to post Share on other sites
KyBlue 655 #6 Posted October 18, 2009 Well, Cant add much, but congrats on the 2 weeks Smoke Free!! Keep it up! Share this post Link to post Share on other sites
Horse Fanatic 51 #7 Posted October 18, 2009 the clicking sound mine makes when I push it sounds like a ball bearing bouncing around. It doesn't sound good but it's normal, I guess it's a check valve. Share this post Link to post Share on other sites
pfrederi 19,293 #8 Posted October 18, 2009 My 418A roll pretty easy but also makes the loud clacking noise. If you try to push it faster there will start to be some resistance. If she goes up and down hill or up out of a ditch when hot you are OK Share this post Link to post Share on other sites
hodge 6 #9 Posted October 19, 2009 Huh... the 520 I had was a bear to push, and it did not make those noises... it was strong and trouble free, though. Share this post Link to post Share on other sites
