KeithB 6 #1 Posted October 16, 2009 1. what size wire should i buy 16 or 18 gauge? 2. where does the ground cable from the battery go, up on the ront of the dash support where the wire channel bolts on? 3. My battery is about 3/4" or so smaller than the batter box, do you shim up with some small pieces of plywood? Thanks Share this post Link to post Share on other sites
WH nut 553 #2 Posted October 16, 2009 What are you wiring 16 would be good for most everything, The ground from the battery should go to the motor, probably mount, if the motor is insolated from the frame then you need to run on to the frame also Share this post Link to post Share on other sites
KeithB 6 #3 Posted October 16, 2009 What are you wiring 16 would be good for most everything, The ground from the battery should go to the motor, probably mount, if the motor is insolated from the frame then you need to run on to the frame also thanks, mine is bolted directly to frame. so how do you shim the battery, will strips of plywood work ok? Share this post Link to post Share on other sites
Save Old Iron 1,573 #4 Posted October 17, 2009 KeithB, don't worry about the footprint of the battery being slightly smaller than the battery box - no shims needed - when you tighten the battery hold down bracket both the battery and the battery box will secured in the tractor. Some battery boxes will have a fitting for a piece of tubing which should be directed down away from the tractor frame - this tubing will direct any battery electrolyte spills out of the battery box and safely onto the ground. :scratchead: Share this post Link to post Share on other sites
TT-(Moderator) 1,170 #5 Posted October 17, 2009 My battery is about 3/4" or so smaller than the batter box, do you shim up with some small pieces of plywood? I used a piece of "1 by" across the back end of the battery in my Charger 12, but a piece or two of plywood would work equally well. Use something thick enough that the nuts on the retaining strap across the end tighten before bottoming out. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ @ Chuck: I believe you're thinking of the newer models. Share this post Link to post Share on other sites
Save Old Iron 1,573 #6 Posted October 17, 2009 Thanks TT for the correction, a good reason I need to stop posting after 18+ hour workdays. Had 416-8 refurb fresh on my brain when I posted. Let me leave with this final word "I see" said the blind man , as he picked up his hammer and saw. Share this post Link to post Share on other sites
