Retired Wrencher
Condenser P/N.
Retired Wrencher
I looking for the part number for a yank 8hp for the B-60. It is different than the rest of the K Kohler's?  Any info would help. This is a bad pick will get a better one today. This engine has one wire with an outside ground.IMG_1579.jpeg.818a8f2a8bae461c0e50eefe6286922e.jpeg
953 nut
 The 235786 condensers are for the magneto equipped Kohler engines only K-161 to K-301.
A magneto ignition system uses a 100 to 250 nF condense.
peter lena
@  Retired Wrencher , regular for  me , on any  used unit , immediately  start  going after  engine VARNISH ? thats what , hangs up piston rings , and related , have to  move areas , typically , exhaust  smoke , like VALVOLINE  OILS  for , much better  cleaning , also use , rislone zinc , in my  stuff , heavily treated  fresh gas , separate gallon jug , engine heat , with correct  additives , break down and dissolve , sticky  varnish , have a regular , process on any  used unit , helps me find what's going on .  none of my engines , smoke , also  enhance any / every  movement  related area , carb linkages , should slide with total ease . just  my 3 cents , pete
Retired Wrencher
A little up date here is better picks of that condenser. I don’t think I’ve ever seen her like that. Does anybody have a part number if that’s the original equipment?
Retired Wrencher
So Richard I found one on EBay as a back up. Thanks for any help.
Edited by Retired Wrencher
