pfrederi
PSA on Sunstrand hydraulic fittings
pfrederi
Do NOT use teflon tape and/or some kind of plumbers putty or epoxy to stop leaky hydraulic line fittings.... The 875 I am working on had some significant leaks.  Tearing it down revealed SAE#5 ORB fittings some with no O rings but some sort of hardened sealer and some had teflon tape (at least that was easy to remove.)  The other stuff I had to scrape and grind and sand out... the deleterious of then fell in to the valve body :angry-nono:
  • Excellent 2
squonk
Teflon on pipe thread fittings- nothing else. And then keep it away from the very end of the fitting.
I remember my days working at a Chrysler dealership replacing several blown turbochargers. The paperwork stated using teflon tape on the oil pressure flare fittings would void the warranty. They were worried about teflon getting into the Turbo seals.  The coolant fittings were pipe thread. I always used teflon on them.
Later in my career I was at a Chevy dealer and had to replace a turbo on a used Chrysler. We used a reman turbo from a local supplier. The turbo drank oil like a fish. The supplier said because I used teflon on the water fittings voided the warranty. I argued if the teflon I used on the water fittings got into the turbo seals, that means water got into the seals as well and their workmanship was defective. I won that argument!
