twoweeks 0 #1 Posted Monday at 01:31 PM HI My Name is Ken and I have been a Red square member for a few years, not knowing there is a european section. I am looking for a c/shaft flywheel key(wooddruff and/or straight) and flywheel nut for my k series kohler engine. I used to get parts from USA, but they seem to block us now. Can you recommend any UK or EU suppliers for these engines. Cheers Ken Share this post Link to post Share on other sites
953 nut 70,589 #2 Posted Monday at 01:38 PM This post should be helpful. 1 Share this post Link to post Share on other sites
Anglo Traction 762 #3 Posted Monday at 09:05 PM Hello Ken, i may be able to help you. I may have the parts you need?. Looking at 953 nut's post above, you've mentioned 12hp 'K' series engine. I have a 1974 12hp K301 47421D crankshaft with nut and washer somewhere. I should also have the square keys for both ends. I can also produce the keys from the correct key steel if you require specific lengths. I can provide part numbers for all of these if you require them. Bye the way, I'm not a business. 1 Share this post Link to post Share on other sites
twoweeks 0 #4 Posted 10 hours ago Hi Richard Thanks for your reply and offer. I did not have time to remove the engine cover and therefore the flywheel before I returned home from France(Where my wheelhorses are). As I know, the flywheel has come loose and I can see the key as well, I am assuming the key has sheared?. Therefore before I return to France in the new year I wanted to take a new key and nut with me. The flywheel has come loose before and I have tightened it back up. If I cannot obtain a new nut, then trying another s/h one and a new piece of key steel hopefully would solve the problem. Therefore I would like to take you up on your offer. Please let me know how much I will owe you. Cheers Ken Share this post Link to post Share on other sites
Anglo Traction 762 #5 Posted 4 hours ago Bit of a worry that the flywheel has loosened before!. Suspect the crankshaft/flywheel tapers may be galled or dirty?. Not wishing to teach 'egg sucking', with the crankshaft nut tightened to 50-60ft lbs, it should not ever loosen. Woodruff/Keyway is only to provide a register for timing, I've found all necessaries. Depends whether you will need the (good) crankshaft as well. I'll send you a personal message (envelope icon at top right of this page) with my location and details. Regards. Share this post Link to post Share on other sites
twoweeks 0 #6 Posted 44 minutes ago Hi Richard It is almost certain the flywheel nut was not torqued to spec. My fault. When the flywheel nut came loose previous I had not touched the engine since buying the wheelhorse. Regards Ken Share this post Link to post Share on other sites
