twoweeks
Kohler K series parts suppliers in England
twoweeks
HI
My Name is Ken and I have been a Red square member for a few years, not knowing there is a european section. I am looking for a c/shaft flywheel key(wooddruff and/or straight) and flywheel nut for my k series kohler engine. I used to get parts from USA, but they seem to block us now. Can you recommend any UK or EU suppliers for these engines.
Cheers
Ken
953 nut
This post should be helpful.
Anglo Traction
Hello Ken,
   i may be able to help you. I may have the parts you need?. Looking at 953 nut's post above, you've mentioned 12hp 'K' series engine.
I have a 1974 12hp K301 47421D crankshaft with nut and washer somewhere. I should also have the square keys for both ends. I can also produce the keys from the correct key steel if you require specific lengths. I can provide part numbers for all of these if you require them. Bye the way, I'm not a business.
