mrharris12 38 #1 Posted 8 hours ago Hi all, for a while I’ve had a slow drip coming from the trans area. From what I can tell I believe it is coming from the in and out on the filter. How easy are those to replace / what do I need to do? I’ll upload a picture here shortly, wouldn’t let me right now Share this post Link to post Share on other sites
lynnmor 9,073 #3 Posted 6 hours ago (edited) First, clean the entire area to see exactly where the oil first appears, also that cleaning is necessary so that dirt doesn't get inside. Hopefully you will only need some o-rings or possibly an oil filter. Another possibility is the seal behind the brake drum. Brake cleaner should do the job and also make the brake work again. Edited 6 hours ago by lynnmor Share this post Link to post Share on other sites
mrharris12 38 #4 Posted 5 hours ago That picture was post me wiping the oil and dirt off. But from my recollection there was wetness at the nuts.The whole process was changing the oil, so i took the moment to see where the leak was coming from. Hopefully it is just o rings 1 Share this post Link to post Share on other sites
953 nut 70,474 #5 Posted 4 hours ago "O" Rings would be a good guess. Be sure to torque them properly. JIC ORB Size SAE Thread Torque Size SAE Thread Torque 4 7/16-20 140 In/Lb 4 7/16-20 220 In/Lb 5 ½-20 180 In/Lb 5 ½-20 260 In/Lb Dash# 905 O Ring 6 9/16-18 250 In/Lb 6 9/16-18 320 In/Lb Dash# 906 O Ring 8 ¾-16 550 In/Lb 8 3/4 -16 560 In/Lb 1 Share this post Link to post Share on other sites
Handy Don 17,703 #6 Posted 1 hour ago 2 hours ago, 953 nut said: Be sure to torque them properly. In that location, the fluid pressure in the tube is quite low UNLESS the filter is clogged. The hose is at low pressure always. Both however, get the full flow of the charge pump at all times. Share this post Link to post Share on other sites
mrharris12 38 #7 Posted 1 hour ago Just now, Handy Don said: In that location, the fluid pressure in the tube is quite low UNLESS the filter is clogged. The hose is at low pressure always. Both however, get the full flow of the charge pump at all times. That filter probably had 150 hours on it (3-4 years old). I put a new one on today (Napa 1410). That possibly will stop leaking? Still worth it to put new o rings regardless? Share this post Link to post Share on other sites
Handy Don 17,703 #8 Posted 1 hour ago 14 minutes ago, mrharris12 said: That filter probably had 150 hours on it (3-4 years old). I put a new one on today (Napa 1410). That possibly will stop leaking? Still worth it to put new o rings regardless? Those hours are not too many, generally speaking, but situations vary, right? That is the correct filter. Note that it does not have an internal bypass valve so that if it does become clogged, it can drastically reduce oil flow which increases pressure in the line that feeds it (the metal tube from the control valve). Me, being frugal, lazy, and protective of my equipment, would keep that area clean as I ran it for a few hours now that the filter has been replaced and would keep an eye on those connections. Dry? No further steps needed. Drippy? Time to address the fittings. Share this post Link to post Share on other sites
