Emann 3 #1 Posted 15 hours ago Hey all, new here. I do CAD and sheet metal for a living and I've been reading about seat and tank mounts cracking on the 300 and 400 series. If yours cracked, I'd love to know: 1. Which model and year? 2. Where exactly did it crack? A photo would be awesome. 3. How did you fix it: weld, angle iron, washers? 4. Would a bolt-on, no-weld fix be useful, or is everyone just welding them? Thinking about designing something. Thanks! 3 Share this post Link to post Share on other sites
Sparky-(Admin) 26,764 #3 Posted 8 hours ago I had a few of mine crack..a buddy of mine welds em up. Latest one was my 83 C-145 auto. The missing piece on the left side I had, so it was welded back in. The other side was cracked only. 2 Share this post Link to post Share on other sites
953 nut 70,466 #4 Posted 8 hours ago I have had the same issue as Mike showed pictures og but I just used a piece of thin angle iron inserted below and bolted in place. 1 Share this post Link to post Share on other sites
ri702bill 13,337 #5 Posted 7 hours ago Over the summer I had 2 identical C81's apart to choose the better pieces.... I ended up removing the three spot welds on both hoodstands and did a mix-n-match as one has a better right half, the other the left side was better. That gave better access to measure & weld. Fabbed up some 1/8 steel angle pieces to weld in underneath as reinforcements. Rejoined the halves with four steel pop rivets. Better than new... 5 2 Share this post Link to post Share on other sites
sqrlgtr 4,199 #6 Posted 6 hours ago The last 312-8 I was working on had began to crack where @Sparky has pictured and i used fender washers to stiffen up, only because I was out of welding wire . if/when I am back in there will try and weld up the cracks and add somthing like @ri702bill has done. that looks like it would really take care of problem. I have only seen one tractor in this series that was not starting to crack, so must be a very common problem with the 300,400,500 series of tractors. 1 Share this post Link to post Share on other sites
peter lena 10,118 #7 Posted 6 hours ago @ri702bill nice save , also watch out , purists say you can't do that , done a lot of functional detailing , enhancing as I went , KEPT GETTING BETTER , also went to shoulder type , bolts , no threading , in swing point , held flat washered , elastic Lok nut . paint it red / black , it disappears , good job , pete 1 1 Share this post Link to post Share on other sites
oliver2-44 11,836 #8 Posted 5 hours ago (edited) The No Names, C 1xx (100, 120, 160 Series has a little seat cracking. The C1x1 (101, 121, 141, 161) C1x5 105,125,145,165) is more like the 300 Series and cracking is common. I have a C1x1 cracked and I'll get a picture of it I have a stick welder, but can't weld thin sheet metal with it. So a non-weld repair would be nice for many of us. Edited 5 hours ago by oliver2-44 Share this post Link to post Share on other sites
ri702bill 13,337 #9 Posted 4 hours ago Can you braze it?? Basicily glueing it together with molten flux coated brass rod.... Share this post Link to post Share on other sites
Emann 3 #10 Posted 2 hours ago Thank you all for the warm welcome, and for all the replies. This is super helpful! @oliver2-44, I'd love to see a picture of your cracked C1x1 when you get a chance. And if anyone can share measurements around the crack area, that would help a ton. Share this post Link to post Share on other sites
