702854boy 1,214 #1 Posted yesterday at 03:48 AM Would anyone have any photos on how to add a lift assist spring to the snow blower on my 854? I tried searching but I haven't found any good photos. I also need the dimensions for the spring and all the hardware needed. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,545 #2 Posted yesterday at 04:25 AM 1 1 Share this post Link to post Share on other sites
ri702bill 13,337 #3 Posted yesterday at 08:58 AM (edited) Gary beat me to it. I added one on the ST-324 mounted to my 854 - it works well. Adjustment is a fine balance of too little or too much though... I had to weld a bent tab to the Flag - I already had the spring. Bought the 3/8-16 eyebolt and a matching Nylok nut. The other end of the spring hooks over the 3/4" diameter rod welded to the frame for the foot rests & pedals. Lowell sells the repro flags & hardware... Edited yesterday at 02:38 PM by ri702bill 1 Share this post Link to post Share on other sites
ML3 2,561 #4 Posted yesterday at 10:53 AM Heres my spring I added on my 702 w/ST323 blower. Adjustment definitely takes some time but once dialed in it the spring makes a big improvement. (I have a very bad back) Also makes a big improvement when you disconnect the rear hitch lift cable if you have weights on hitch! Stupid me didn't even think of that at 1st whenever I was installing spring! 🙄 1 1 Share this post Link to post Share on other sites
squonk 48,370 #5 Posted yesterday at 11:28 AM Make sure the lift flag is connected to the hole closest to the rock shaft centerline. 1 Share this post Link to post Share on other sites
peter lena 10,118 #6 Posted yesterday at 01:14 PM @ML3 like that , another thing I regularly use is a TURNBUCKLE , lets you DIAL IN A SPRING ASSIST , LUBE AS YOU GO . do you have a dense rubber isolation pad , on that weight arm to bottom of rear end ? greatly reduces the pin point weight on a casting . pete Share this post Link to post Share on other sites
Handy Don 17,702 #7 Posted yesterday at 02:51 PM 3 hours ago, ML3 said: How much weight is that!? Share this post Link to post Share on other sites
ML3 2,561 #8 Posted yesterday at 04:37 PM 1 hour ago, Handy Don said: How much weight is that!? Only 50lbs. 3 hours ago, peter lena said: @ML3 like that , another thing I regularly use is a TURNBUCKLE , lets you DIAL IN A SPRING ASSIST , LUBE AS YOU GO . do you have a dense rubber isolation pad , on that weight arm to bottom of rear end ? greatly reduces the pin point weight on a casting . pete Its only 50lbs of weight on back. Its bolted thru a hitch flat drawbar 1 1 Share this post Link to post Share on other sites
702854boy 1,214 #9 Posted 35 minutes ago One issue I am finding is that the snowblower doesn't disengage. I just put a new TSC blue belt on it that was slightly bigger than the old one but it still doesn't disengage. Share this post Link to post Share on other sites
