702854boy 1,205 #1 Posted 9 hours ago Would anyone have any photos on how to add a lift assist spring to the snow blower on my 854? I tried searching but I haven't found any good photos. I also need the dimensions for the spring and all the hardware needed. Share this post Link to post Share on other sites
ri702bill 13,320 #3 Posted 4 hours ago (edited) Gary beat me to it. I added one on the ST-324 mounted to my 854 - it works well. Adjustment is a fine balance of too little or too much though... I had to weld a bent tab to the Flag - I already had the spring. Bought the 3/8-16 eyebolt and a matching Nylok nut. The other end of the spring hooks over the 3/4" diameter rod welded to the frame for the foot rests & pedals. Lowell sells the repro flage & hardware... Edited 4 hours ago by ri702bill 1 Share this post Link to post Share on other sites
ML3 2,559 #4 Posted 2 hours ago Heres my spring I added on my 702 w/ST323 blower. Adjustment definitely takes some time but once dialed in it the spring makes a big improvement. (I have a very bad back) Also makes a big improvement when you disconnect the rear hitch lift cable if you have weights on hitch! Stupid me didn't even think of that at 1st whenever I was installing spring! 🙄 1 1 Share this post Link to post Share on other sites
squonk 48,354 #5 Posted 1 hour ago Make sure the lift flag is connected to the hole closest to the rock shaft centerline. Share this post Link to post Share on other sites
peter lena 10,114 #6 Posted just now @ML3 like that , another thing I regularly use is a TURNBUCKLE , lets you DIAL IN A SPRING ASSIST , LUBE AS YOU GO . do you have a dense rubber isolation pad , on that weight arm to bottom of rear end ? greatly reduces the pin point weight on a casting . pete Share this post Link to post Share on other sites
