CCW
Mow deck spindle question
CCW
The 36 in RD mower deck on my 312-8 is nearly 40 years old.  It has always been garage and the shell is as solid as the day it was bought.  Over the past couple of years I have been adding grease via the zerks and all appears to work great though it is very loud while engaged.
My concern is the grease at the bearings.  Does it dry out that new grease may not be reaching the bearings?  How do I know if I have added enough grease?  Or is this a case of if it ain't broke don't fix it?  I hate to disassemble the deck if there is no sure benefit.
Edited by CCW
8ntruck
It is probably time to disassemble the spindles.  If you have noise that wasn't there in the past, something has changed - a bad bearing, a worn shaft, etc.  Check the spindles individually for smooth rotation, end play, and radial play.  That should give you a clue as to which one is the worst, therefore the one to start on.  Remember, all the spindles have been in service the same amount of time.  If one is bad, the others probably are reaching the end of their service life too.
I've got three decks that I need to have that done.
